#1 |
![]() Join Date: May 2007
Hello out there ...
After a particularly sweltering day I came back to my 1999 SL1 to find that the parking brake button was missing from the handle. It and the spring were on the dash. It looks like two little clips on the edge of the button are ripped, but if I try I can put the spring and button in and use the brake again ... until the car gets hot. Then, *poof*, it flies out again. Any tips on how to repair this without going to the dealer? Thanks, Dave |
#2 | |
![]() Quote:
All it cost me was the $2 admission fee to the junkyard.
Mike -1991 Turbo SL2. 11.809 @ 116.488 mph www.differentracing.com -2001 Limited Edition SC2 (#78) -2001 Chevrolet Suburban -2007 Saturn Aura XR -2011 Rally Yellow Chevrolet Camaro 2SS RS |
#3 |
It's not a particularly expensive part even from a dealer and it takes literally 5 minutes to put on. There's a screw that holds the plastic brake handle cover on take that out, pull the cover off, and it's obvious how to replace the button. The part is called a parking brake button assembly.
There is nothing more frightening than ignorance in action. |
#4 |
#5 |
![]() ![]() Join Date: Jul 2005
$22+ at saturnparts. Take a trip to the yard.
"When you stop to fill up on oil, don't forget to check the gas" 98 SL2 MT 213K+ Daily Driver 38+ mpg 97 SL2 AT 150K Original Owner 95 SL2 MT 220K+ My Saturns have BRASS ones! |
#6 |
![]() Join Date: Jul 2009
Try here, if he still carries them:
Flat tip: milehighoutlet(dot)ecrater(dot)com/p/4888440/saturn-parking-brake-handle-button-and Round tip: milehighoutlet(dot)ecrater(dot)/p/4888336/saturn-parking-brake-handle-button-and Also carries the dome lights in gray and beige!! |
#7 |
![]() Join Date: Jun 2010
1999 SC1
There is a RICHPIN video on youtube for that. Go to a junk yard for the part.
#8 |
This thread is 3+ years old, and the OP never posted again... so I highly doubt the OP will see this message, or even cares any more
I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 151k DD 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles |
#9 | |
![]() Join Date: Jan 2009
1999 SW2
![]() Quote:
#10 |
Fair enough
#11 |
1999 SW2
Thanks for the welcome, alordofchaos
![]() I've actually lurked here off and on for a few years now and got some great help replacing the electric window motors on my '99 SW2 some time ago. Richpin06's youtube vids were a big help along with some awesome posts by forum members here. For the parking brake button I went with a paper clip fix that was briefly mentioned in another thread. It works a treat, and is actually better than new because now there's no plastic tabs to worry about breaking. A 1/16" hole is drilled through both the button and the white arm, then held together with a metal paperclip inserted through the holes. Of course you want your spring in place before permanently joining the button and arm. I used a larger sized paperclip, slipped it through the holes, cut off the excess, bent and then crimped the ends so it can't come loose. After installing and sliding the cover on you can't tell it isn't oem ![]() It took longer to gather the tools than it did to do the job lol Again, thanks for the welcome, and to all who post some really great help here. Last edited by billcat; 08-03-2011 at 03:37 PM. |
Bookmarks |
Handbrake Button - Parking brake handle button | EarlyMR | S-Series General | 31 | 03-15-2022 01:39 PM |
1996 SL-1, parking/emergency brake button sprung out | AtlanticBeach | S-Series Tech | 13 | 01-01-2012 11:47 PM |
Removing the parking brake cable from the park brake lever | turbobuick33 | S-Series Tech | 3 | 12-29-2008 07:32 PM |
Button on Parking Break Popped off! | omphaelos | S-Series Tech | 2 | 07-14-2008 12:00 PM |
Parking Brake Button | dave.sl | S-Series Tech | 1 | 01-09-2008 12:51 AM |
