Old 05-20-2012, 12:44 AM   #1
dr_lee29
dr_lee29 is on a distinguished road
Default Strange electrical issues
We have a 2002 SL1 with 174,000 miles. Bought it new, can't say enough good about this car, we love it.
Over the weekend, we drove 4 hours on the interstate to a relatives house. We didn't have any problems on the trip there, parked the car over night. The next day, the car wouldn't start (not even a click), we jumped the car and it started right up. But now the strange part, a bunch of things don't work on the car now. AC doesn't work (the compressor doesn't come on), day time running lamps don't come on, rear window defroster is on constantly, THE ODOMETER MOVED BACKWARDS (from 174,000 to 169,000), the trip odometer reset, I don't think the radiator cooling fan is coming on, radio clock skipped (now 30 minutes late). The car seems to run fine, we drove it home 4 hours. I do not see any blown fuses.
Any ideas (maybe we hit a time-warp?)? I suppose as long as the odometer keeps moving backwards, I should be happy!
dr_lee29 is offline   Reply With Quote
Old 05-20-2012, 11:27 AM   #2
dsquare86
dsquare86 is on a distinguished road
2002 SL1
2001 SL2
Default Re: Strange electrical issues
How are those battery terminals? Clean and free of corrosion? Tight?
dsquare86 is offline   Reply With Quote
Old 05-20-2012, 05:25 PM   #3
dr_lee29
Pretty tight but would loose cables explain the AC odometer and other problems?
Old 05-20-2012, 08:05 PM   #4
You may have more than one issue. If the car wouldn't start and needed a boost then there may be battery/battery cable/cable connection/loose belt/alternator problems. Battery age? Cables corroded? Loose drive belt? Alternator? These questions only address why the car needed a boost start. Why the odd ball indications is another matter.
Some errant indications are from the body control module. The a/c control signal goes through the bcm. Defrost, daytime running lamps and maybe the odometer. Search past threads about bcm's. Removing battery negative for a minute may help reset electronics.
What's been replaced with 174k miles?
Old 05-22-2012, 05:00 PM   #5
dr_lee29
Unplugging the battery seems to have fixed the bugs. I have not looked into the alternator yet to figure out why the battery died in the first place.
Old 05-22-2012, 05:33 PM   #6
Did the odometer return to its correct value?
Old 05-23-2012, 05:58 PM   #7
dr_lee29
Yes the odometer returned to its correct number!
1998 SL2 strange electrical issues nutty123 S-Series Tech 5 01-22-2012 10:41 PM
Strange electrical issues ARS_Lurker S-Series Tech 3 01-12-2012 04:26 PM
Strange electrical issue mlt01SC2 S-Series Tech 0 07-14-2010 11:30 PM
Strange electrical problems.... spfrancis S-Series Tech 4 07-12-2005 10:03 AM
Strange electrical problem 99 SL2 Niteshooter S-Series Tech 2 07-04-2005 09:18 AM
