#1 |
![]() Join Date: Dec 2009
Hi I am working on a 1998 Saturn SL1. The problem is when you leave off the gas to shift the rpms stays high. If you leave the clutch in for a bit the rpms thens drops to normal. Other systems are hard start or rough idle after start mainly when cold. It is also using considerable more fuel. Auto Zone tested the car and t returned a temperature sensor error. I replaced that sensor, but I don't believe that was the problem as it wasn't hooked up to begin with.
Could a egr valve or throttle position senor cause these simtems? Any suggestions appreciated |
#2 |
Welcome to Saturnfans
![]() I'd start with cleaning the throttle body, especially around the sides and back of the plate, to see if that fixes the slow drop to idle. Might just be gunked up. This is a link to richpin's videos on Youtube - there's one that shows how to remove/clean it. Did you notice the condition of the coolant temp sensor (aka ECTS)? If it had any corrosion on it, it needs to be replaced. Simply cleaning it out won't work... ask me how I know ![]() How to replace the ECTS connector. You got the ECTS error because it was unpluggled. When it's plugged in, but the original resin tip is cracked or the connector is corroded, you won't get an error (service engine soon light) but it will cause the hard starting and high fuel usage you mentioned. More useful links" The How To Library http://www.differentracing.com/tech_articles/index.html
I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 151k DD 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles |
#3 | |
![]() Quote:
1997 - SL2, barebones, 161k, Auto - Rebuild complete and.. burnt a valve 20k later Arrgh! Purchased 114k 10/07 Added OEM CC |
Bookmarks |
Bad idle, drops rpms quick between shifting | Ikiris | S-Series Tech | 8 | 08-09-2009 10:04 AM |
High Idle AND now High RPMs 1995 SC2 | randibou | S-Series Tech | 3 | 03-20-2009 05:52 PM |
Sometimes hard to start, slightly high idle | Insulator | S-Series Tech | 5 | 03-15-2009 12:07 PM |
Hard Shifting, Stall Out and Hard Start | lswatts | L-Series Tech | 6 | 12-11-2008 03:28 AM |
High rpms and not shifting right | WrenchForce | S-Series Tech | 2 | 12-03-2006 01:51 PM |
