#1 |
![]() Join Date: Jan 2005
Guys,
Can I remove the door panel with the door closed? I cannot get the door to open and am thinking that I need to access from the inside. How do you remove the door panel from the inside with the door closed? chevy57 |
#2 | |
![]() Quote:
The latch is most likely damaged, I've seen it happen a few times. The only way to open the door is to smash apart the latch using a long screwdriver down between the glass and door frame from the outside. ![]()
Mike -1991 Turbo SL2. 11.809 @ 116.488 mph www.differentracing.com -2001 Limited Edition SC2 (#78) -2001 Chevrolet Suburban -2007 Saturn Aura XR -2011 Rally Yellow Chevrolet Camaro 2SS RS |
#3 |
Thanks. I did finally get it open and removed the latch. It was rusted solid. I think I will coat the new one with anti seize.
chevy57 |
#4 |
So we don't need to bash apart the panel to bash the latch to pieces? Then pay $20 for a can of paint on the new panel? Sweet, I'll let a friend of mine know...he hasn't been able to open the driver side rear door since he's owned it.
The proper way to fix a S-Series automatic is to replace it with a manual |
Bookmarks |
Drivers door won't open | VueinNC | Vue General | 2 | 10-12-2009 10:31 AM |
2005 Vue Drivers Door Won't Open | spencer1984 | Vue Tech | 2 | 02-07-2008 03:17 PM |
2000 LS1 Rear drivers-side door is stuck in the lock position | sjoyce54 | L-Series Tech | 3 | 01-08-2008 10:58 PM |
chime on when drivers side door open | skenzer | S-Series Tech | 3 | 06-25-2007 01:20 PM |
Help!! drivers door won't open! | Speedbump | S-Series Tech | 6 | 01-12-2006 11:49 PM |
