Old 12-01-2022, 02:53 PM   #1
RICH1959
RICH1959 is on a distinguished road
Default S series tech
not sure where to post this but I am in need of a good s series tech not sure if there is anyone in the st Louis Missouri aera on the site that know of anyone
RICH1959 is offline   Reply With Quote
Old 12-01-2022, 06:28 PM   #2
93twincam
93twincam is on a distinguished road
2002 SL1
Default Re: S series tech
What's the issue you're having? Saturns are pretty simple cars and this forum has a wealth of knowledge and people who can help walk you through diagnosis and repair.
2002 SL1 5 speed - 165,xxx - Current daily
1993 SC2 5 speed - 200k - Unfortunately sold
2002 Silverado Z71 - 185,xxx
2007 Impala 3.5L - 365,xxx - Still running good, daily backup
93twincam is offline   Reply With Quote
Old 12-01-2022, 06:41 PM   #3
RICH1959
Its a 1999 sw2 automatic the car has a shifting problem so i had a rebuilt trans installed still have the same problem they said it must be something electrilal or ecm problem i am not good with this type of repairs was hoping to find a saturn guru in my aera
Old 12-02-2022, 09:31 AM   #4
trottida
trottida's Avatar
I would focus in on the valve body. I'm not 100% sure what is involved in rebuilding a transmission but if they didn't do anything to the valve body, that was likely the original issue. They would have likely torqued the input shaft nut as part of the rebuild. Ask them what was done to the valve body in the transmission rebuild.
If the maintenance schedule for transmission fluid and filter changes are not followed the valve body passages tend to get clogged up. The issue first presents as a delay and slam when going into reverse known as reverse slam. If not attended to right away then the input shaft nut losses torque and backs off. Eventually you start losing other gears.
If reverse slam is caught early you can follow Wolfmans Reverse "Slam" Cure in Saturn Autotransaxles. If not caught early then you are in for valve body replacement and a retorque of the input shaft nut.
1999 SL2 MT (311,300 km @ 01/2023)
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 12-02-2022, 07:51 PM   #5
RICH1959
They said they did all the updates on the valve body with the updated valve
Old 12-05-2022, 08:52 AM   #6
Highmile
Highmile's Avatar
Unless they replaced the shift solenoids and line pressure solenoid I would start there. Pretty much all you need is an ohm meter and a diagram on the trans electrical connector.
Who did the trans?
btw, I'm in the stl area.
Highmile
'95 SL1 767k and counting
Old 12-06-2022, 09:23 PM   #7
RICH1959
Pm sent
Fan repalcement (moved for L-series Tech) cginstructor S-Series Tech 1 08-20-2008 11:40 PM
Saturn vue vs. S-series (tech aspect) junker S-Series Tech 8 02-11-2008 06:05 PM
New S-Series Forum - post S-series tech issues there? coolgreany General Saturn Discussion 0 05-13-2003 11:28 PM
Tech bulletin on 01 S series brakes? Anubis Miscellaneous Tech 5 08-12-2001 11:59 PM
Saturn -S- Series tech. tip danielwau Miscellaneous Tech 0 12-31-2000 02:51 PM
