#21 |
![]() Join Date: Apr 2009
I thought AZ was Arizona. haha
'92 SC... Digging the DOHC :D |
#22 | |
![]() Join Date: Mar 2009
Until I find a replacement button, I've solved the problem with things that were laying around in the car: I have a modestly strong zip-lock baggie (that some auto part came in) placed over the end of the parking brake handle and rubber banded to the handle. I suppose we could call this solution 'the parking brake condom'. ![]() |
#23 |
![]() Join Date: Jul 2009
Same thing just happened to me on my 95 SW1. Seems like there are 2 different designs for this lever. I found a replacement for $12 + ship at this store:
milehighoutlet.ecrater.com There are 2 designs listed so check the pics. |
#24 |
Find the components that popped off.
Remove the plastic boot covering the handle. There is a fillips head screw on the passenger side near the base of the handle. Pull the boot off. Remove the white plastic part that is in the metal handle. Put the black thumb knob back on the white plastic extension. Drill a 1/16" dia hole in the good plastic above the 'break' through both pieces. Remove the black knob. Place the spring on the white plastic holder. Put the black thumb knob back on the white plastic extension. Thread a paper clip through the hole you just drilled. Cut the paperclip to length and bend over the ends so it can't come out. Assemble as you took apart. Takes longer to find the tools than it does to complete the work. |
#25 |
![]() Join Date: May 2011
does anyone know where I can buy this piece. Some one posted AZ in this blog, so I'm assuming he ment auto zone, but I looked on auto zones online store and can't find it.
#26 |
![]() Join Date: Apr 2011
Well my 97 sl2's button also flew out of the emergency brake handle. I got frustrated when i saw how much they wanted for the parts to get it fixed. But the solution was as close as my tool box. I found a forgotten tube of 5 ton epoxy resin. And since i didn't feel like spending $100,00 i took the cover off the emergency brake put epoxy gel inside the broken button put the spring on and put the plastic piece in place put on and held the button down for 10 minutes with my bare hands until set to usable strength and now it works perfectly.
#27 |
![]() Join Date: Jun 2007
You just revived a 4 -1 year old thread.,Good job. Lets throw you a party.
2002 SL2 115k "Whisper" No leaks!! :) 115 and going strong.. |
#28 |
![]() Join Date: Jul 2012
Ok, my ebrake handle button popped off this morning when I stopped for gas after church. The force with which it and the spring flew to the windshield was highly amusing at that point but as the day wore on, it has been increasingly more difficult to get the brake to engage which as the original poster mentioned, is a bit of a problem as this is a manual transmission car and I also live where I have to park on a steep hill!
Once I get the replacement button, will it simply pop into place and then work beautifully like before? Thanks so much for your help! |
#29 |
![]() ![]() ![]() ![]() ![]() Join Date: Jun 2010
I have not seen the replacement buttons. We have a U-Pull yard near me that always has several S-series cars.
When mine broke, I just picked up a replacement there for 1 or 2 bucks. Its pretty easy to replace. Only tool needed is a philips screwdriver to remove the rubber boot. To get the white arm out, you have to push it all the way in and then rotate it downward. Pretty easy once you figure it out. To reinstall it, there is a little metal thingy that you have to flip downward to get the white rod to lock in place. I pulled mine from an Auto car of the same generation. I figure that auto cars will tend to use the e-brake less often, so it will have less use/abuse. |
#30 |
![]() Join Date: Nov 2021
I imagine that since this post came from 2009 and now it's 2022 that Auto Zone no longer offers this part. Same for the post for this part found in Columbus, so anyone know if any of the aftermarket parts places still offer the fix?
#31 |
It's 2022!
![]() It also means you can print your own (what a time to be alive!) https://www.thingiverse.com/thing:2119090 (I don't have a 3D printer but turns out that colleges, community colleges, and some high schools do - if you know a student, it is cheap/free)
I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 151k DD 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles |
#32 |
![]() ![]() Join Date: Oct 2006
2000 SL1
1995 SW2
You can use two part epoxy as mentioned earlier in this thread. The e-brake button on my wife's '98 did the same thing not long after I bought it a couple of years ago. Epoxy works fine and is easy to do.
'85 Ford LTD Squire '89 Cougar XR-7 5 Speed '95 T-Bird SC 5 Speed '97 T-Bird LX '91 Crown Vic P72 351W '98 Saturn SW2 5 Speed (wife's car) |
Parking brake/handbrake | My own VUE | Vue General | 6 | 10-14-2017 03:31 PM |
1996 SL-1, parking/emergency brake button sprung out | AtlanticBeach | S-Series Tech | 13 | 01-01-2012 11:47 PM |
Parking brake button popped off ... help! | davenavarro | S-Series Tech | 10 | 08-03-2011 03:27 PM |
Parking Brake Button | dave.sl | S-Series Tech | 1 | 01-09-2008 12:51 AM |
handbrake button?! | skyski02 | S-Series General | 4 | 10-27-2005 05:07 AM |
