Old 10-03-2020, 10:44 PM   #1
BrandonKastning
BrandonKastning will become famous soon enough
BrandonKastning's Avatar
2001 L-Series 3.0L Sedan
Wrench 2001 Saturn L300 - v6 3.0 Liter - Draining The Radiator Fluid / Coolant
Hey everyone!
I purchased the upper radiator hose and the lower radiator hose. However when reading the Factory Service Manual; it mentions the Head Degas hose (which of course I didn't end up getting, DOH!)
Can I drain the coolant by replacing/pulling the Upper Radiator Hose? Prepping to change my Water Pump before the Snow
Thanks in advance!
“For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.” - John 3:16 (KJV)
Last edited by BrandonKastning; 10-03-2020 at 10:45 PM. Reason: forgot a few things :)
BrandonKastning is offline   Reply With Quote
Old 10-04-2020, 07:23 AM   #2
Dsaturn
Dsaturn is just really niceDsaturn is just really niceDsaturn is just really niceDsaturn is just really nice
2001 L-Series 2.2L Sedan
Default Re: 2001 Saturn L300 - v6 3.0 Liter - Draining The Radiator Fluid / Coolant
Since there is this thing called gravity water runs down not up. Pull the bottom hose or use the drain plug on the radiator.
https://www.infowars.com/ The answer to 1984 is 1776. We are not a Democracy. We are a Constitutional Republic. A Democracy is Two Wolfs and a sheep deciding what is for Lunch!
Dsaturn is offline   Reply With Quote
Old 10-04-2020, 08:34 AM   #3
BrandonKastning
Thumbs Up Re: 2001 Saturn L300 - v6 3.0 Liter - Draining The Radiator Fluid / Coolant
Dsaturn,
Thank you! Bottom hose will work and a drain plug on the radiator! 10-4!
Cheers!
Best Regards,
~ Brandon
Old 10-04-2020, 09:53 AM   #4
Rj 2000 LS2
Rj 2000 LS2 is just really niceRj 2000 LS2 is just really niceRj 2000 LS2 is just really niceRj 2000 LS2 is just really nice
2000 L-Series 3.0L Sedan
I'm not sure the entire contents of the engine coolant jacket will be emptied merely by disconnecting the bottom hose and most 20 year old radiators don't have a working drain. You could take it to an oil change place that flushes the coolant system, but then you stand the chance of screwing the thermostat and getting to and changing the thermostat requires removing the entire top of the engine and all intake manifold(s) which is exactly what you would need to do to replace the valve cover gaskets. So start there.
Rj 2000 LS2 is offline   Reply With Quote
Old 10-04-2020, 10:05 AM   #5
lrbraner
lrbraner is a jewel in the roughlrbraner is a jewel in the roughlrbraner is a jewel in the rough
2002 L-Series 3.0L Sedan
2003 L-Series 3.0L Wagon
I agree with pulling the bottom hose or opening the drain plug. My experience has been that i needed to drain the radiator, fill with water, warm the car up, drain the radiator again. Did this 3 times before there was no trace of coolant left in the system.
I used the radiator drain as i replaced I with a new one at the start of this process.
2002 L300 Sedan
2003 LW300 Wagon
2005 L300 Sedan
lrbraner is offline   Reply With Quote
Old 10-04-2020, 10:11 AM   #6
ernesto rex
ernesto rex is a jewel in the roughernesto rex is a jewel in the roughernesto rex is a jewel in the rough
ernesto rex's Avatar
Hey Brandon,
Just curious if you were going to replace the timing belt at the same time you are replacing the water pump.
Ernesto
2000 LS2 (Sold, Sigh)
2003 VUE 3.0 FWD
2002 MINI Cooper R50
1978 GMC PU 7.4L
2020 Subaru Impreza
ernesto rex is offline   Reply With Quote
Old 10-04-2020, 11:31 AM   #7
BrandonKastning
lbraner,
I appreciate the re-affirmation and your method of flushing. I will also do the same thing now that it's been mentioned! Much appreciated!
Best Regards,
~ Brandon
Old 10-04-2020, 11:35 AM   #8
BrandonKastning
Originally Posted by ernesto rex View Post
Hey Brandon,
Ernesto
ernesto rex,
Yes sir,
I will be replacing the timing belt, the timing belt tensioner, and both pulleys; at the same time I also will be replacing the camshaft seals and the crankshaft seal. (I will take pictures of my work - win or lose) and post here as usual.
I just needed to know exactly how to drain the engine properly per experts here on saturnfans.com.
Dsaturn and lbraner have helped tremendously on this thread as usual.
Best Regards,
~ Brandon
Old 10-07-2020, 11:49 PM   #9
BrandonKastning
Thumbs Up [SOLVED] 2001 Saturn L300 - v6 3.0 Liter - Draining The Radiator Fluid / Coolant
Thanks everyone! I used the radiator p plug to drain my coolant. I didn't have a small little hose to fit over the plastic outpouring piece; I tried to make a large one to run off into a jug; and that failed. I ended up just filling up when it was draining over the oil catch rail/bar/jack-mount-area.
Best Regards
~ Brandon
Tags
gm l81, radiator coolant flush, saturn l300
2001 Saturn L300 - v6 3.0 Liter - DNJ Engine Overhaul Kit - Anyone? BrandonKastning L-Series Tech 42 10-01-2020 02:03 PM
2001 Saturn L300 - v6 3.0 Liter - Puller Fan BrandonKastning L-Series Tech 57 06-30-2020 03:17 PM
2001 Saturn L300 - v6 3.0 Liter - VCX NANO vs. GM L81 (1 Hour+ Run) BrandonKastning L-Series Tech 38 06-26-2020 12:36 AM
2001 Saturn L300 - v6 3.0 Liter - Fog Lights (Parking Ones) BrandonKastning L-Series Tech 4 06-16-2020 11:15 PM
2001 Saturn L300 - v6 3.0 Liter - Preparing a Coolant Flush w/ DEX COOL Orange BrandonKastning L-Series Tech 18 03-26-2020 03:22 PM
