Old 10-08-2009, 07:35 PM   #1
spiderpig24
spiderpig24 is on a distinguished road
spiderpig24's Avatar
1994 SL1
Default hellpppp big mistake made!
i Accidently but Transmission fluid in my Clutch fluid thingamabobber.....How do i bleed the clutch fluid in a 94 saturn SL1
spiderpig24 is offline   Reply With Quote
Old 10-08-2009, 07:37 PM   #2
dorisSL
dorisSL is on a distinguished road
dorisSL's Avatar
1995 SL
Default Re: hellpppp big mistake made!
no bleeding possible on the saturn clutch assembly.
i'd recommend a turkey baster, suck a few squirts out (not below the bottom of the reservoir, though) then replace with DOT3 brake fluid. repeat until it's good.
1995 SL, born 12/23/94, manual, WAI 190,500, "Doris"
(I'm Ben, the car is Doris)
you can't mulch at those speeds man, that's too fast
dorisSL is offline   Reply With Quote
Old 10-08-2009, 07:53 PM   #3
spiderpig24
1994 SL1
thanks....
Old 10-08-2009, 07:55 PM   #4
dorisSL
dorisSL's Avatar
1995 SL
now, the real question, you were topping off your clutch reservoir, so clearly you'd lost fluid. where did it go?
Old 10-08-2009, 07:56 PM   #5
RobertGary1
RobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to all
A slower method is to suck small amounts into a straw and then spit it out. That's how I got rid of the oil around my spark plug!
-Robert
Old 10-09-2009, 12:11 AM   #6
Christ
Christ will become famous soon enough
2001 L-Series 2.2L Sedan
I'd put the cap back on, and use it anyway. If you're losing fluid, and you keep having to top it off, over time, you'll end up with good fluid in there anyway. Meanwhile, tranny fluid won't hurt anything any more than DOT3 would, and it retains the same hydraulic properties. It will also leak out faster from wherever it's leaking from, so you'll be able to notice it and possibly repair it.
You really can't bleed any part of the clutch components? What do you do when you have to replace either a slave or master cylinder?
Christ is offline   Reply With Quote
Old 10-09-2009, 12:17 AM   #7
dorisSL
dorisSL's Avatar
1995 SL
its a sealed system, i don't know the replacement procedure, but i know it's easy to screw up
Old 10-09-2009, 12:18 AM   #8
Christ
That sucks.
Old 10-09-2009, 12:24 AM   #9
crystal scan
crystal scan is on a distinguished road
2003 ION-2 Sedan
i would what of happen if he drove it
crystal scan is offline   Reply With Quote
Old 10-09-2009, 12:30 AM   #10
postmortal1
postmortal1 is on a distinguished road
1991 SL2
1993 SL2
I wouldn't worry about it..ATF in there is not the end of the world. If it still disengages, RUN IT!!
If you do pull the slave cylinder out of the Bell housing you have to line up the rod into the yoke again. They come with a one time use clip on them new that breaks the first time you push in the clutch. I use a needle nose vise grip to hold it and align it while I insert the Slave again, once its in the yoke your golden.. Used that method the last time worked mint.
There is a thread on here somewhere discussing bleeding the normally sealed master slave assembly.. I think it is how to library..
postmortal1 is offline   Reply With Quote
Old 10-09-2009, 12:30 AM   #11
sierrap615
sierrap615's Avatar
ATF and DOT 3 are both hydralic fluids, but designed for very different porpuses. i would worry the ATF may have damaged the seals. how much did you put in? the clutch components are sold as an assembly, salve and master cylinder are not sold seperatly.
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
sierrap615 is offline   Reply With Quote
Old 10-09-2009, 12:59 AM   #12
Get the ATF out.
It is a petroleum based fluid that will likely swell every rubber component in the system.
Old 10-09-2009, 10:17 AM   #13
PIYIRIO
PIYIRIO is on a distinguished road
Originally Posted by ssicarman View Post
Get the ATF out.
It might stop his leak then...
PIYIRIO is offline   Reply With Quote
Old 10-09-2009, 10:47 AM   #14
mattelderca
mattelderca will become famous soon enough
mattelderca's Avatar
1998 SC1
1996 SL
Generaly ATF in a clutch or brake system will soften the seals and cause a failure of the system. It is in the master now so I suspect that to fail first, leaving you with no clutch, very bad deal.
As per the posts above, IF you were low on fluid you needed to service the system anyhow.
2000 SL1 freebie, my sons DD
1998 SC1 still running, FOR SALE cheap!
1996 SL, GONE but not forgotten
2005 Generic Silver Minivan (Kia Sedona)
2009 Nissan Sentra 2.0S
mattelderca is offline   Reply With Quote
Old 10-09-2009, 12:57 PM   #15
RobertGary1
There are two answers to that question...
1) You can buy the OEM replacement which includes the master and slave cylinders with fluid already in them.
2) There are after market parts that allow for bleeding.
Here is what Saturn says....
"WARNING: Do not attempt to bleed the clutch hydraulic unit. Any observed fittings are there for factory use only. The unit comes as a complete pre-bled unit. "
-Robert
Old 10-10-2009, 01:24 AM   #16
SLCraig
It's very easy to change.... 30 min job for someone that's done it before, maybe 45 if you haven't.
Some could maybe do it even sooner, but I take out the airbox, battery, battery tray, etc... The rest is cake.
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
Old 10-10-2009, 01:28 AM   #17
Christ
So by the sounds of it, you don't have to pull the tranny to do it, so that's better than I thought.
IIRC, we did have to pull the tranny on my Father's 1998 S-10 to replace the slave cylinder. I was very unhappy, we had just replaced the damn clutch, then the slave went out about 400 miles later.
Old 10-10-2009, 03:53 AM   #18
vtsl2
vtsl2 is on a distinguished road
vtsl2's Avatar
the hardest part about changing the clutch hydrolics, is getting the master off the firewall, other than that it is very simple.
oh and by the way on s-10's the slave is bolted to the outside of the trans, ford rangers are on the inside with the clutch. f***in FORDS and thier better ideas
SATURNS ROCK: THATS ALL I HAVE TO SAY
01 sc2m mine
93 sc2m my sons
06 chevy 2500 crew 6.6 DMAX
99 sw2a converted to manuel now a race car
02 chevy Silverado extened cab stepside
99 sl2m retired
vtsl2 is offline   Reply With Quote
Old 10-10-2009, 11:07 AM   #19
Christ
Ok, maybe it was pulling my Father in Law's Ranger tranny out then. Either way, i'm tired of working on micro-trucks with bad engineering decisions.
I'll be glad when my Taco's parted out, and I can get my Dakota project going. Mid-size truck FTW.
Tags
bleed, clutch, fluid, proble
Big Mistake? almoore S-Series Tech 3 10-29-2009 10:52 PM
i think i made a mistake buying the 05 vue @ clearance time m4gician Vue General 58 02-23-2006 07:47 PM
mistake i made to my ride Azn_IoN Ion General 19 06-07-2005 05:20 PM
Wow, I almost made a $13K mistake... GreyDuck General Saturn Discussion 54 12-05-2004 02:45 PM
Big Mistake saturnrings General Saturn Discussion 13 10-27-2003 10:59 AM
