Old 07-29-2001, 11:33 PM   #1
1996SL2
1996SL2 is on a distinguished road
Default P0302 - Cyl. 2 Misfire---HELP
I know what the code is....can anyone give me an idea of what to do about it. Thanks
1996SL2 is offline
Old 07-30-2001, 09:10 PM   #2
sattech
sattech is on a distinguished road
Default
Start with checking the plug wire at the EI coil for corrosion. Check the plug for carbon tracking ( vertical black lines on plug ceramic) inspect plug electrode. check plug wire on open ckt.
Note: if you find carbon tracking, replace both the plug AND the wire
~ If it worked before you messed with it, it must be something you did ~
sattech is offline
Old 07-31-2001, 02:27 AM   #3
1996SL2
Default
Thanks I'll check that and let you know
1996SL2 is offline
P0302 cyl. #2 missfire, but doesn't feel like it? ajs_saturn S-Series Tech 1 11-30-2009 01:42 PM
Error Code P0302 Misfire pospo Ion Tech 3 06-26-2009 09:52 PM
96 SL2 P0302 misfire code mbolena S-Series Tech 5 12-05-2007 03:17 PM
96 sl2 P0302 Cylinder 2 misfire??? bskicrash1 S-Series General 15 12-26-2005 12:22 PM
P0302 Cylinder 2 misfire. M.Nguyen S-Series Tech 4 04-07-2005 12:33 AM
