Old 09-10-2021, 06:42 PM   #1
CM400T
CM400T is a jewel in the roughCM400T is a jewel in the roughCM400T is a jewel in the rough
2001 SL2
Happy Driver's door lock issue
Hello,
Ever since I bought my silver 2002 SL2 in 2005, the driver's door lock has been a little "dodgy". Now something has finally failed. When I insert the key into the lock and turn it, it will lock the door, but not unlock it.
(BTW, it is the same car as this thread. I finally got around to finishing it only two weeks ago. It was nice to have it working again. And after 150,000 miles, I pre-emptively put a brand new starter on, so I can have confidence in it.)
For now, I will need to use key fobs or unlock the right front door and use the "door unlock" button.
Is this a "linkage" problem or a lock cylinder issue?
Is the manual window crank difficult to remove? I suspect both outer panel and inner panel (armrest) will need to come off, right? What tools do you recommend for this?
(I am fairly familiar with taking the outer plastic panel off, but it has been several years since I did one.)
CM400T is offline   Reply With Quote
Old 09-10-2021, 08:13 PM   #2
Waiex191
Waiex191's Avatar
Default Re: Driver's door lock issue
https://youtu.be/BoxTGyVCXX8
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 10-18-2021, 05:19 AM   #3
marieturner
marieturner is on a distinguished road
Thanks for your video. It sure did help.
marieturner is offline   Reply With Quote
07 Ion 2 Driver's Side Auto Door Lock Issue ParrishIon Ion General 3 05-17-2021 11:58 AM
07 Vue driver's door lock problems KermitDRambler Vue Tech 4 06-24-2015 11:54 AM
Driver door will not lock with me in the car kosoku Vue Tech 5 12-11-2013 12:26 PM
Driver Side Door Lock Zvolen S-Series General 7 01-03-2011 01:24 AM
Driver door key lock rikeman Ion General 2 05-02-2007 08:13 PM
