Old 10-23-2016, 08:00 PM   #1
deca5423
deca5423 will become famous soon enoughdeca5423 will become famous soon enough
2004 VUE Red Line
2006 ION-2 Quad Coupe
Default Completed valve adjustment on my 3.5
Completed the valve adjustment on my 3.5 which was probably long overdue at 146k. I don't think I touched a single intake valve but the exhaust valves were so tight that I couldn't even fit the gauge in. The first valve I tried was an exhaust valve and I was really confused at where the hell the gauge was supposed to go, it was that tight!
For anyone else looking to do this I would clean the electrical harnesses above the valve covers well. They don't really move out of the way and the crud on them kept falling in the engine every time I bumped them. Probably took me 10 hours start to finish over a few days. Someone more experienced could probably do it in half the time. I bought the special tool as well which was very nice but I couldn't use it on two of the back exhaust valves because the firewall is too close.
Before the adjustment I had noticed if I started the car and shut it off while it was still cold it would kind of sputter out like I cut off the gas and it was still trying to fire. This issue is now completely gone. Had two instances where it stalled out completely on a cold start. Seems to have a bit more pep in it's step too but that could be in my head
deca5423 is offline   Reply With Quote
Old 10-23-2016, 08:50 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: Completed valve adjustment on my 3.5
You have lots of nerve ... and I mean that in a good way.
Did you ever have SES ... and if yes ... you recall specific codes?
Did you locate a complete gasket kit or order separate gaskets?
You have numbers in either case?
Again ... well done and thanks for the thread!
Old 10-23-2016, 09:04 PM   #3
RobertGary1
RobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to all
I found the intake to need a bit of tightening and the exhaust were slightly too tight. Overall the adjustment was so small i wouldn't bother with it again. No difference in performance. The bigger risk is someone not familiar with measuring valves misreading the gauge (you have to be careful with the angle). Most shops only allow their master techs to do this because of this.
-Robert
Old 10-24-2016, 08:37 AM   #4
underthehood
underthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the rough
underthehood's Avatar
2004 VUE 2.2L
Amazes me in this day and age Honda hasn't figured out there are automatic hydraulic cam followers. (lifters).
2006 Toyota Highlander (rare 4 cyl AWD)
2001 Toyota Highlander V6 AWD creampuff
Daughter got her own! 2005 Lexus ES330 Dream Ride
underthehood is offline   Reply With Quote
Old 10-24-2016, 09:04 AM   #5
deca5423
2004 VUE Red Line
I never had any codes even for the stalls on cold start, which surprised me. The two stalls were even years apart. The thing I noticed with the rough shut off was it only happen if I shut it off while it was still cold. It was noticeable because I have to back the vue out to get to my lawn mower.
I reused the same gaskets. They were in great condition and I just made sure they were clean and well seated.
I suspect my car may have been a little abnormal in how off the exhaust valves were. I used the 0.305 for exhaust and 0.229 for the intake and I could barely fit the 0.229 gauge in the exhaust valves. Like I said I didn't touch the intakes because they 'felt' good enough.
Old 10-24-2016, 09:54 AM   #6
far2grumpy
far2grumpy's Avatar
None of following is meant to detract from your willingness to get at the rocker arms and adjust valves - that is so cool.
Exhaust valves could be a "tad" out of tolerance ... here are numbers from factory service manual:
• Intake valve adjustment: 0.2-0.24 mm (0.008-0.009 in)
• Exhaust valve adjustment: 0.28-0.32 mm (0.011-0.013 in)
You mention being able to insert 0.229 (0.009) in exhaust valve lash so I don't see the slight "tightness" as being a problem.
Old 10-24-2016, 10:21 AM   #7
deca5423
2004 VUE Red Line
Thanks, I understand
Your ranges appear to be correct with the stickers that Honda prints on the J series cars for valve adjustment:
-Intake 0.22 +- 0.02
-Exhaust 0.30 +- 0.02
Hopefully I have this right, and I will round up slightly to make this easier. 0.229 = 0.23 and 0.305 = 0.31.
The 0.23 gauge was a tight fit in my exhaust and the low end of the range for the exhaust is 0.30 which would make it unacceptably tight, correct? I feel confident I did this correctly because my cold start/shut off problem is now completely gone and I adjusted only the exhaust valves to fit the 0.31 gauge.
Old 04-02-2019, 12:57 PM   #8
Red_Vue
Red_Vue is on a distinguished road
Quick question for you.. I can't seem to find a solid answer.
The order is 1,3,5 closest to the cabin, left to right
And 2,4,6 closest to the radiator left to right... Correct?
Red_Vue is offline   Reply With Quote
Old 04-02-2019, 01:56 PM   #9
far2grumpy
far2grumpy's Avatar
Bank 1 - nearest cabin - cylinders are 1, 2 and 3 counting from front of engine (accessory belt end) to rear (toward transmission).
Bank 2 - nearest radiator cylinders are 4, 5 and 6 front to rear.
Old 04-02-2019, 05:26 PM   #10
atikovi
You set the front bank cam sprocket to the #1 mark in the timing belt cover window, then adjust cylinder 1 valves in the picture. Then turn the crank to the next cylinder and continue on.
Old 04-02-2019, 08:16 PM   #11
KCW
KCW is on a distinguished road
2004 VUE 2.2L
reading this thread and I thought it was an aprils fools joke
google honda V6 engine valve adjustment, and I still cant believe honda would make ANY car engine that did not have hydraulic lifters
since I have scrapped out my last saturn I have been driving Ford and Toyota cars now, always held honda in high regard, but there is no way in hell I would buy a car that requires the valves to be manually adjusted, at any interval
it was easy to do on old air cooled VWs, and it was suppose to be done every 3000 miles with the oil change
the website I found said the valve adjustment on a honda V6 is a 4 hour job
I never even heard of this before - I dont mind checking and adjusting valves on my motorcycles, because they are very simple engines, small, light and powerful
but on a car? No way.
KCW is offline   Reply With Quote
3.5L valve adjustment RobertGary1 Vue Tech 10 12-08-2017 06:58 PM
Valve adjustment /lash ? Endders S-Series Tech 3 10-28-2011 06:03 PM
L200 Valve adjustment epekarik L-Series General 1 02-27-2006 12:51 AM
Valve adjustment? Gee3 S-Series Tech 8 02-25-2006 12:08 PM
99sw2 Valve Adjustment LilRedWag Mods and Performance 2 06-27-2000 06:02 PM
