![]() ![]() ![]() Join Date: Dec 2010
Greetings.
I have a 2001 SC2 that will need a clutch eventually. While the transmission is out, I'd like to have the differential modified or replaced to avoid having it self-destruct somewhere down the road. The transmission has no shifting issues or problems of any kind. It has nearly 300,000 miles on it, though, so I'd like to address this one failure point at the very least. Although I could probably deal with it on my own, I will not be doing this myself, as I have other projects that need my immediate attention. Can anyone recommend a competent shop in eastern PA or anywhere in NJ who can install a limited slip, upgrade the pin, otherwise address the inherent differential issue? |
![]() ![]() Join Date: May 2004
I'm on Long Island. I never did any Trans work on my saturns.
A guy in my area once offered to do a trans rebuild on my TAAT. I could maybe contact him (I'm in Bay Shore; Islip area, 1 hr offpeak driving from NYC). tbhpmciAThotmailDOTcom Last edited by TomM96; 05-12-2022 at 08:41 PM. Reason: fergat un |
Cheaper to just not spin the tires on pavement than rebuild the transmission
![]() If you want to rebuild anything, upgrade/rebuild the shift cables to use heim joints (McMaster 6072K31 on trans end and 6072K154 on the shifter), I know a few members have documented rebuilding them on here, Waiex191 is the only one I'm thinking of right now. '99 SL2 and a '98 SC2, not sure where in the threads the transmission rebuild comes up but I believe its in one of those 2. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2016
Post 174 and on:
http://www.saturnfans.com/forums/sho...=230898&page=9 Not sure how common the failure is. Ours was fine at 204K. Probably not worth it unless you are a nut. You don't have to remove the transmission to change the clutch.
Bryan Cotton '99 SL2, 5SP bought new Rebuilt at 204,067 September 2017 Engine, subframe, diff pin mod, brake lines, headliner, alternator, and so on! '98 SC2, 5SP bought 2018 |
#5 | |
At the very least, I'd like to put a new upgraded pin in there. I saw several threads on this subject, but I've yet to see a part number for the beefier pin. Does anyone have one? Also, I suppose I can just move the transmission back far enough into the wheel well to gain access to the clutch? Will there be enough room to remove the flywheel as well? |
#6 | |||
https://sites.google.com/site/hunt4s...n/transmission You can search for user hunt4steve but I think the pictures on Saturnfans are gone - but the link above works. Quote:
#7 |
Excellent!
#8 | |
as for replacing it, once you take the transmission apart enough to get to the diff, it's dead simple. drive the old one out, marvel that it was still holding while in multiple pieces (every single one i've replaced was) and then drive the new one in.
rings-1996 sl2 ~215k mi phoebe-1995 sl1 ~250k mi janus-2000 sohc2 ~190k mi tethys-1994 sw2 ~302k mi rip mimas-wrecked 1996 sw1-trailer pandora-1999 sc2 dione-1998 sw2 penny [iapetus]-1997 sw2 |
#9 |
It is good to hear that this is, essentially, a permanent solution. When the time comes, this is definitely the route I'll be taking, unless I acquire a limited slip unit in the interim.
I had no idea OldNuc passed away. It seems he's passed into legend. His posts will be sought out and quoted for a great many years to come, so long as people drive Saturns. |
#10 |
it is truly a shame, but well, i suppose his username wasn't youngnuc. his advice truly is legend on this forum.
#11 |
![]() ![]() ![]() ![]() ![]() Join Date: Mar 2017
1995 SW2
I will warn that the upgraded pin is not a definite solution, and the same goes for welding the diff pin.
I have blown a trans with a beefed up pin, it lasted maybe a few months of abuse on the turbo car, and I know of a person that has done the same with a trans with a welded pin. The best solution is to spend the extra coin on a limited slip diff. Ever since I got mine it has been no worries and I never have to think about blowing the trans.
1994 Sl2 5spd: First Car, Stock: 56,576 (Totaled 1/10/2018) 1994 Sl1 5spd: Inherited, Stock: 494,500 1995 Sl2 5spd: Retired Daily, Not Stock: 196,000 1995 SW2 4spd: Daily, Stock: 104,000 |
#12 | |
When I replace the gearbox in my '98 I'll do the diff pin mod.
#13 |
1995 SW2
This is not necessarily true, it depends on the hardness of the pin. Generally, the harder the metal, the more brittle it is. Nothing to do with whether or not it is a coil format.
Seeking advice | spitoon | Astra General | 9 | 09-24-2019 08:27 PM |
transmission top gasket part number and torque wrench recommendation | wrparks | S-Series Tech | 10 | 12-20-2012 09:56 AM |
Desperately Seeking Help | johnicelavon | S-Series General | 5 | 04-28-2006 10:08 PM |
Desperately Seeking Help | johnicelavon | S-Series Tech | 8 | 04-28-2006 09:52 AM |
V6 Engine Seeking | davbow | L-Series General | 3 | 10-27-2003 02:33 PM |
