Old 12-23-2009, 06:57 AM   #1
Naru
Naru is on a distinguished road
Default Drivers' door stuck as "open" - Help!!!!
01 SL2 Saturn -
I installed a new speaker yesterday. I had to remove the door panel in which I had little problems. After everything was put back together, the door is now "stuck" as open. When it isn't. The door opens and closes fine, it's just something is reading the door as open when it's not.
The alarm won't lock (3 beep warning) but will unlock via remote. It locks/unlocks fine on the inside, but not with the remote. The interior light stays on when set to DOOR mode. When the key is left in the ignition it chimes like the door is open unless the car is on.
I need some major help here, because I can't use my alarm/lock/interior light until I figure out what I screwed up.
Naru is offline   Reply With Quote
Old 12-23-2009, 07:23 AM   #2
Naru
Default Re: Drivers' door stuck as "open" - Help!!!!
Sorry for the double-ish post. New to the forums, and this one explains my problem more clearly.
Old 12-23-2009, 10:19 AM   #3
I'd start with checking the door switch... it's a little plunger-type thing that gets pushed in when the door is closed. It's pretty closed to the area that you were working. Usually, it's black plastic but I haven't checked on the s-series.
Old 12-23-2009, 12:53 PM   #4
saturnsctwo
that's what i explained to him on the other thread, as i can't imagine what else could be the problem. maybe when he removed the door panel it doesn't line up with the switch properly or something, or the switch broke while he was removing the panel? maybe the panel hit the switch while removing?
Old 12-23-2009, 01:04 PM   #5
Yeah, I see the other thread now
Guess we should just post on that one...
Drivers door won't open VueinNC Vue General 2 10-12-2009 10:31 AM
Help!! drivers door won't open! Speedbump S-Series Tech 6 01-12-2006 11:49 PM
Do all older Saturns "RUST" under that plastic "THINGY" that sits under the door???? Token S-Series General 21 09-08-2005 10:14 PM
Will unplugging O2 put "warm" obdII car in open loop?? tgferg67global S-Series Tech 1 06-24-2005 05:30 AM
Open exaust causing engine "miss"????? Jon94SoLo2 S-Series Tech 4 05-21-2001 06:50 PM
