![]() ![]() ![]() ![]() Join Date: Mar 2015
I recently had to remove the column to remove the dash to fix the recirc main door to the actuator. Of course I had to remove the stubborn upper bolt buried up above between the mounting bracket. How in the H-B Jeever's did the factory get that bolt in there ?! So far it's next to impossible. I had to remove the Wiring loom plastic guide by the brake pedal to even get close enough to the bracket and STILL can't get it. I'm not even sure what bolt came out of it, so I found a smaller bolt, washer and nut to try and slide it thru and just put a nut on the other end with Still no success. I never got the one on my L200 back in a few years ago either, I just put in the 2 bottom ones and called it good. Had the same issue then. I may have to just Forgettabboutit !, unless anyone has any Sure Shot way than what I know, or can see, which is another problem. It's a little wobbly right now. Bolts are as tight as I can get them. Thanks for the advise.
Sorry, Rear Bolt.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2015
2002 L-Series 3.0L Wagon
I agree that top bolt that comes in from the back is a pain. I think I used a wobbly socket and an extension and said a few choice words. With the seats out I can lay on the floor with my head by the pedals. It is a very awkward position to work in.
2002 LW 300 loaded, only 95,000 original miles! 2002 L200/5 Loaded, 275,000 miles 2000 LS1, TMU love those bcm failures. |
Exactly, I was thinking about that way as well. As long as I have the seat out, I may as well give it a good vacuum too. lol. There's always some Varmint Goodies under there. A little cold out, but I can fire up the garage heater.
Steering column bolt stuck | Raincitygears | S-Series General | 1 | 02-05-2019 05:09 AM |
steering intermediate shaft to steering column bolt | flymanansh | Aura General | 4 | 02-07-2012 04:40 PM |
one time use bolts on steering column? 2000 SL2 | davebugs | S-Series Tech | 10 | 05-11-2008 02:06 PM |
rubbing noise steering wheel/steering column on 04 Vue | ynotps | Vue General | 6 | 03-03-2005 08:59 PM |
Question Re 2000 SL1 Steering Column | BobL | S-Series Tech | 11 | 06-08-2002 10:32 PM |
