Old 02-04-2023, 02:58 AM   #1
csmolen
csmolen is on a distinguished road
2002 SL1
Default Aftermarket ECU
any of you know if a MS3-Pro ecu would be plug and play for an SL1? and dont give me the twin cam lecture im well aware.
csmolen is offline   Reply With Quote
Old 02-04-2023, 09:40 AM   #2
Macgyver
Default Re: Aftermarket ECU
They're not plug and play, but were used in boosted twin cam applications.
https://auto.jepistons.com/blog/a-tu...oxs-saturn-sc2
Old 02-05-2023, 09:22 PM   #3
csmolen
2002 SL1
so obviously Id have to flash it with something to get it to they dyno, but what i kinda meant by plug and play is if the wiring would match.
Old 02-05-2023, 09:50 PM   #4
cgg17
cgg17's Avatar
1995 SW2
Custom wiring, no direct plug in solution exists.
1994 Sl2 5spd: First Car, Stock: 56,576 (Totaled 1/10/2018)
1994 Sl1 5spd: Inherited, Stock: 495,000
1995 Sl2 5spd: Retired Daily, Not Stock: 198,000
1995 Sw2 5spd: Daily, Stock: 110,000
Old 02-06-2023, 02:54 AM   #5
Signmaster
No tuning solution is plug and play for an S Series, unless you can find a scam resistor on Ebay claiming it's some kind of power chip. Those should plug right in.
With a stock engine, even a standalone system and proper tune might net you all of a couple HP. The money would be better spent on oil in all honesty. Even on the twin cam engines there isn't a lot to be had, and with the SOHC even less.
Signmaster is online now   Reply With Quote
Old 02-07-2023, 08:08 PM   #6
cgg17
cgg17's Avatar
1995 SW2
For a stock S-Series, it is absolutely worthless.
Unless you are going to make a high compression build, or implement forced induction, take Signmaster's advice and buy some good oil...
Aftermarket anything Kilo702 Astra General 20 09-29-2017 01:45 AM
What's the best aftermarket EGR to buy? 2strkBlu S-Series Tech 3 08-15-2011 05:39 PM
OEM vs. Aftermarket spotana98 S-Series Tech 10 01-28-2008 08:02 PM
Aftermarket for 2.4 PlumSL1 Ion Mods 2 03-20-2006 09:09 PM
VUE and the aftermarket snowdog General Saturn Discussion 1 01-06-2004 12:54 AM
