Old 06-27-2004, 03:38 PM   #1
1993
1993 is on a distinguished road
Default Trans code 25, engine code 32, 1993 sl-1
Just bought a 1993 sl-1 SOHC saturn, 119K on it, doesnt look like its ever been off the showroom floor, nice car, it is giving me a code 32-EGR and a trans code 25, no TCC, i have 2 questions, first will it hurt it to keep driving it with the no TCC in the trans?
Next, i checked the EGR valve, i pushed the plunger up and then help my finger over the hose connection and the plunger stayed up until i released my finger, so it seems to be good, so would the problem likely be the solenoid? if so, is an autozone solenoid sufficient or is it one of those things were the dealer item should be used?
thanks BTW, when i got it, the trans fluid looked perfect but i had it changed anyways to be sure..
1993 is offline
Old 06-27-2004, 06:09 PM   #2
ym42
ym42 is on a distinguished road
Default
I think the problem would most likely be the solenoid itself, or the vacuum hoses. I would get it from Saturn, at least check the price difference between AutoZone and the Dealer. It might cost the same. I do not like AutoZone that much recently, but this is my personal opinion. Driving without TCC will not damage anything, but will give you worse fuel economy, in the city, not so much on the highway. Do you get your SES light constantly on?
ym42 is offline
Old 06-27-2004, 06:47 PM   #3
1993
Default
na, its not constantly on, just comes on every now and then to remind you i guess..lol..i was told that the code 25 for the inoperatice TCC was usually caused by a leaking o-ring on the torque convertor input shaft as they had a technical service bulletin on it in 1993, wonder how to find out if its the o-ring or the TCC solenoid? but you say either way it wont screw anything else up in the tranny or shorten the trannies life by running it with the TCC not working?
thanks
1993 is offline
Old 06-27-2004, 11:13 PM   #4
Lucas1
Lucas1 is on a distinguished road
Default
the code 25 - no TCC will not effect driveability, but it will effect fuel economy. an aduible test can be done on the solenoid, but you have to have a tech 2 to do it. other that that you have to remove the tranny to determine the problem.
Lucas1 is offline
check engine code 11, coolant hot light flashes code 23, 95 SL2 2003MercMaraude S-Series Tech 2 10-23-2009 06:17 PM
code 43 1993 SC2 sctuner89 S-Series Tech 1 08-08-2009 12:48 AM
HELP SES Code 26 and 32 1993 SW2 snguyen S-Series Tech 7 12-16-2007 01:00 AM
PCM error code 32 in 1993 SL1 meseville S-Series Tech 10 09-17-2003 04:37 PM
1993 SL1 diagnostic code 49 ??? RobB2 S-Series Tech 2 04-18-2003 07:40 PM
