Old 05-11-2022, 04:47 PM   #1
Rj 2000 LS2
Rj 2000 LS2 is just really niceRj 2000 LS2 is just really niceRj 2000 LS2 is just really niceRj 2000 LS2 is just really nice
2000 L-Series 3.0L Sedan
Default Passenger size floor matt is full of Dex Cool
I have had this issue once before and it vanished for a long time. Over the winter, somehow, the Saturn was leaking coolant and the light came on to add coolant. I added 2 inches of Dex Cool to stop the light indicator. I saw the passenger side floor mat had the Dex cool color and it felt wet in the center, but no real path or track of "leak".
This morning, I removed the plastic side cover to expose the heater core and connecting pipes. I drove the car for several miles and then inspected the heater core and connections to the pipes. I put paper towels beneath the heater core and the pipe connections. I felt nor saw any dex cool on these items to signal where the leak is coming from. I even wiggled them and no leak were found.
Is it possible to have cold leak vs a hot leak? It seemed to only leak while the car was sitting and not being used. Is it haunted? There is no identifiable source of the leak. The mat appears to only have antifreeze pooling in the middle of the mat and nothing around the center counsel.
Any ideas? I could simply buy a heater core with attached pipes and install that, but I would really like to isolate the problem rather than shot gunning parts.
Rj 2000 LS2 is offline   Reply With Quote
Old 05-17-2022, 08:46 AM   #2
Rj 2000 LS2
Default Re: Passenger size floor matt is full of Dex Cool
I placed two paper towels beneath the heater core another under the pipe connections. I left them there for 3 days. I found drips beneath the pipe connections and none under the heater core. I suspect the O-ring is leaking. Are the O-rings a standard size or are they special? Has anyone ever disassembled the plastic pipe connection and replaced the O-rings?
Old 05-18-2022, 03:04 PM   #3
Russet
Russet has a spectacular aura aboutRusset has a spectacular aura about
2002 L-Series 3.0L Sedan
I have but don't recall but I don't recall replacing the o-ring and you should be able to get them from the local shop or if you replace the heater core I think they have replacement o-rings for them as well. But check to be sure your heater core isn't plugged or in need of replacement as well.
Old 05-19-2022, 09:44 AM   #4
Rj 2000 LS2
I'll flush the heater core when I replace the O-rings. However, when it comes to heat, the Saturn heats better and faster than our other two vehicles (Dodge Ram 2500, and an 2000 Yaris Hach Back).
Would a standard O-ring from an O-ring kit fit the heat pipe?
Does anyone know the specs on the O-rings?
I can find the O-rings from many sites. They cost $11-$16 each.
I haven't found any where to purchase new heat pipe retainer clips. I am so hard on plastic. I worry I'll break them when I take the off.
Old 05-19-2022, 11:30 PM   #5
pierrot
pierrot's Avatar
Originally Posted by Rj 2000 LS2 View Post
... I can find the O-rings from many sites. They cost $11-$16 each.
In your last sentence you stated your concern with breaking plastic parts, and I have been hard on plastic parts, too. Additionally, the plastic parts have aged and may be more brittle as a result. In that case I'd be inclined to purchase a replacement heater core which also included the seals and plastic retainers as well, and such are available. This could mean a better use of one's time knowing all parts can be replaced and there would be no worry over a broken part.
374K miles - Holy canolli!
Biden/Harris predictions, '21 -'25: weak economy; weaker military; more terrorism; emboldened RED CHINA. Sadly, B & H are proving me correct...too bad... now Russia?!
passenger floor still wet mlc5 Vue Tech 9 12-11-2015 04:48 PM
Lost a floor matt DrPimper S-Series General 5 05-05-2009 02:30 PM
wet passenger floor 98 SL2 bfitz S-Series Tech 5 07-01-2006 10:41 PM
'98 SL2 Wet Passenger Floor joe525 S-Series General 3 12-23-2005 10:55 AM
Wet passenger side floor dragonheartck Vue General 4 06-12-2005 02:13 PM
