Old 03-16-2011, 03:06 PM   #1
JohnHupp
JohnHupp is on a distinguished road
Default Head gasket removal technology
In past projects, I have used a number of methods to remove gasket material. I'm having a fresh look at the question as I ease back into an engine repair that I started several months ago. I also want to get this right on the first try -- I replaced a valve cover last year with RTV, not long after that went on a long trip, and it started leaking (perhaps not enough cure time). I ended up redoing the job with an OEM pre-formed gasket, but only after a mighty struggle trying to free the cover. The RTV was holding on for dear life in every spot except where the leak was. So as I prepare this block for reinstalling the head, I don't want something like that scenario again.
The FSM says:
Using a gasket scraper, Scotch Brite Pads and Disk (3M Clean 'N Strip 2 in. D x 1/2 in. W x 1/4 in. center hole) remove all the gasket material from the cylinder block, oil pan, rear seal carrier, and front cover surfaces.
But I'm having a hard time pinning down a match for that at 3M. Following is the portal for all the candidates. Of the four categories, I'm confident that I'm not looking for a wheel, but probably something under that first choice for Scotch-Brite Discs:
http://solutions.3m.com/wps/portal/3...bePZBKJFSK8Ggl
But clicking on that still leads to a bunch of choices. I'm guessing the FSM may be indicating one of the "surface conditioning" products, and probably not something with a Roloc attachment since it says "1/4 in. center hole."
But apart from what the FSM says, I saw another post here where someone liked the Roloc bristle brushes for this job (with white, green or yellow pad). So I'm interested in what you think about the alternatives.
That brings me to another question which the FSM manual doesn't even raise -- what "grade" or "grit" to select in any of these given pads.
Obviously there will be more than one way to get this done, but if I'm going to buy something, I want to get something that will do a nice job without scratching the mating surfaces.
JohnHupp is offline   Reply With Quote
Old 03-16-2011, 04:15 PM   #2
blue92
blue92 will become famous soon enoughblue92 will become famous soon enough
1992 SL1
Default Re: Head gasket removal technology
I think I used a gasket remover from Permatex once. Worked real good, but dont get the stuff on your skin.
92 SL1 original owner
94 SL2 Homecoming
98 SC2 White Hot
02 SC2
blue92 is offline   Reply With Quote
Old 03-16-2011, 05:01 PM   #3
Acetone, green scotch brite, 1 1/2" spring blade putty knife after the edge has been sanded to a bevel.
If you are going to have the block boiled out then just strip it down and ship it off.
Old 03-16-2011, 06:20 PM   #4
bountyhunter
bountyhunter will become famous soon enoughbountyhunter will become famous soon enough
1992 SL2
Single eded razor blade held perpindicular to the surface to scrape and a lot of patience. Scotchbrite pad to polish the surface. Steel scrapers will gouge the aluminum and make a mess of it.
bountyhunter is offline   Reply With Quote
Old 03-16-2011, 06:20 PM   #5
JohnHupp
Do you mean "green scotch brite" as in the common scotch brite rectangular pads, or one of the round, mounted automotive pads?
I'm already expecting that I'll need to have the block pressure-tested since I found a corroded head bolt. What's a ball-park price for having a block boiled?
Old 03-16-2011, 10:19 PM   #6
If you had water in with a head bolt then pull the engine from the car and strip the block of all removable parts except the oil gallery plugs and start calling shops to get a price to hot tank, pressure test and measure your block. Should be about $50.00 The square green pads work just fine. Send all the aluminum parts to the hot tank, does not materially increase teh price and makes assembly much more pleasant.
Old 03-17-2011, 09:52 AM   #7
JohnHupp
Thanks, OldNuc. If I'm going to have a shop do that work, do I still need to remove the gasket material, or does all that come off nicely in the hot tank?
And if I'm going to replace valve guide seals in the head, is there any reason not to put that in the tank also?
Old 03-17-2011, 11:16 AM   #8
The hot tank will get rid of the gunk and dead gasket. The head has to be stripped down before tanking. For the 250 it will cost you I would let the shop grind the valves and replace the seals. A good shop will get the gaskets you need for the rebuild cheaper than you can buy them yourself. the shop will test both the head and block for cracks in the bargain. As you are doing an overhaul you can usually order all the parts you need to assemble the rebuilt engine. On the big scheme of things it is cheaper and easier to do this way. The basic disassembly and reassembly work you do. You get to disassemble the lifters and clean them out though. So you remove the cams, sensors, and lifters - the rest goes to the shop. High end bearing, Sealed Power pistons and rings bore and hone the block are usually things you buy through the shop.
Old 05-18-2022, 10:43 AM   #9
mattwithcats
mattwithcats is a jewel in the roughmattwithcats is a jewel in the roughmattwithcats is a jewel in the roughmattwithcats is a jewel in the rough
I iike the brown Scotch Brite better than the green.
Less abrasive, my no stick kitchen pans still look like new...
https://www.scotch-brite.com/3M/en_U...3786499&rt=rud
Pennzoil Maximum Power 0W-30, Champion COS3600...
NGK BKR6E-11 spark plugs
Old 05-24-2022, 06:50 PM   #10
Signmaster
The brown ones are good pads....
..... but you've fallen prey to a spammer bumping and old thread!
coolant leak...head gasket, cracked head, or water pump? BRIAN41920 S-Series Tech 13 01-11-2013 04:18 PM
Is it possible to repair a oil leak from the head gasket without replacing gasket? tgferg67global S-Series Tech 13 12-23-2010 08:39 PM
SW2 number 1 cylinder wet - Head gasket or Intake Manifold gasket? jcw S-Series Tech 4 05-09-2008 03:42 AM
Head gasket, head bolts and other head related foolishness… Quagmire S-Series Tech 9 09-12-2007 10:08 PM
cracked head,valve cover gasket or cam gasket leaking ???how to tell !! maestro S-Series General 11 06-04-2006 04:26 AM
