Old 02-15-2006, 07:18 PM   #1
Jeff03Vue
Jeff03Vue is on a distinguished road
2005
Default Vue V6
Is the Vue V6 3.5L, The same engine as the Malibu Maxx V6 3.5L ?
How does one find such info?
Jeff03Vue is offline   Reply With Quote
Old 02-15-2006, 07:24 PM   #2
SylenThunder
SylenThunder is on a distinguished road
SylenThunder's Avatar
2003 VUE 2.2L
2004 VUE 2.2L
Default Re: Vue V6
browse around the threads for a while. BTW, you've got a honda engine. The one in the MAXX is the same they have been using for a while in the Olds line.
2004 FWD, Vti, 2.2L
Custom CAI
SylenThunder is offline   Reply With Quote
Old 02-15-2006, 07:46 PM   #3
Jeff03Vue
2005
Default Re: Vue V6
No I don't have one, I have the 2.2L.
But didn't know where the Maxx engine came from.
Thanks
Old 02-15-2006, 08:44 PM   #4
Charlie
Administrator
Charlie has a brilliant futureCharlie has a brilliant futureCharlie has a brilliant futureCharlie has a brilliant futureCharlie has a brilliant futureCharlie has a brilliant futureCharlie has a brilliant futureCharlie has a brilliant futureCharlie has a brilliant futureCharlie has a brilliant futureCharlie has a brilliant future
Charlie's Avatar
2008 Outlook XR
2005 VUE Red Line
Information Re: Vue V6
Here's some information about the GM 3500. Hope this helps.
Charlie
2008 Saturn Outlook XR
2005 VUE Red Line
2002 L300 (sold)
Charlie is offline   Reply With Quote
Old 02-15-2006, 10:44 PM   #5
OhioVueBoy
OhioVueBoy has a spectacular aura aboutOhioVueBoy has a spectacular aura aboutOhioVueBoy has a spectacular aura about
OhioVueBoy's Avatar
Location: N. Bethesda, Maryland (DC) (Dayton Ohio Native)
2002 VUE 2.2L
Default Re: Vue V6
Ooh and note that the 3500 is NOT the same as the new GM 3.5 liter. The 3.5 has VVT, the 3500 does not.
~D.J.~
2012 Mercedes Benz C250 Sport Sedan
2008 smart fortwo Passion Coupe 8/28/2008 - 3/12/2012
2002 VUE FWD4m - Gone but not forgotten. 5/14/2002 - 10/31/2011
OhioVueBoy is offline   Reply With Quote
Old 02-16-2006, 09:09 AM   #6
fastdrvr23
fastdrvr23 is on a distinguished road
fastdrvr23's Avatar
1992 SL1
Default Re: Vue V6
Great article in the Pdf above!
I'm sitting here at work with a spec sheet in front of me (I work at Mahle, we make pistons and all sorts of other stuff for automotive applications www.us.mahle.com) and I thought it might help with what's written here...
For the 3.5L in the Vue, here's what listed:
Displacement (L): 3.5, cc: 3471, Code: L66, Manufacturer: Honda, Locat.: Anna, OH, 05' # Produced: 46,900, Materials: Cyl Head (AL), Block (AL), Layout: V-6 (60 degrees), Bore x stroke: (89mm X 93mm), Compression Ratio: (10:1), Performance Hp/RPM: 250/5800, Torque lb/ft: 242/4500, Fuel System/Valving/Valve Actuation: SFI/DOHC/4vpc/VVT, 2006 Models Installed: Saturn Vue, Connecting Rod: Cast Iron Fracture Split, Camshaft Type: Cast Iron, Intake Manifold: Cast Aluminum...
Strangely enough, the I just noticed something on the other 3.5L's built in Anna, OH used in the Odyssey, Pilot and Ridgeline. The engine's code is listed as J35A, but there are some pretty fundamental differences in the fuel delivery and valvetrain setup, for the fuel system/valving and valve actuation it has the following listed: MFI/SOHC/4vpc/VTEC. Hmmm, I didn't realize they were a SOHC setup. Their con-rods are different as well, Forged powder coated fracture split, and a 1 piece Cast Crank. Heavy duty stuff...
We have a plant in Ramos Arizpe also, where they assemble the GM 3.5L. We make the pistons and con-rods for that motor.
The GM 3.5L V6 mentioned above is coded as the LX9, used in Malibu/Malibu Maxx/G6/Montana/Relay/Terranza/Uplander/Rendezvous.
The other GM 3.5L V6 has a couple of codes listed: LZ4, LZ5, LZE its used in the Monte Carlo and Impala.
Both the GM 3.5L are push-rod, roller rocker engines... SFI/OHV nothing fancy like VVT (for 05' manufactured engines at least).
The 3.6L LY7 used in the CTS and such has SFI/DOHC/VVT
2006 Saturn Vue V6 FWD - Sold in Jan. 07'
2007 Nissan Frontier King Cab SE
2003 Mazda Protege5
1992 Saturn SL1
fastdrvr23 is offline   Reply With Quote
Old 02-16-2006, 11:41 AM   #7
Jeff03Vue
2005
Default Re: Vue V6
Thanks for that info Charlie, good stuff
Old 02-16-2006, 05:18 PM   #8
cdp326
cdp326 is on a distinguished road
cdp326's Avatar
2007
Default Re: Vue V6
The 3.5 in the MC/Impala does have VVT.
"It's a car. We've invented the Pontiac Aztek."
cdp326 is offline   Reply With Quote
Old 02-16-2006, 06:20 PM   #9
fastdrvr23
fastdrvr23's Avatar
1992 SL1
Default Re: Vue V6
Yeah, sorry about that, I goofed that up. The LX9 is the one that didn't have VVT.
The 3500 LZE's (the flexible fuel variety for Montes and Impalas) and LZ4's (Montes and Impalas) have VVT...
2003 Mazda Protege5
1992 Saturn SL1
Old 02-17-2006, 08:25 AM   #10
vue-vtec
vue-vtec is on a distinguished road
vue-vtec's Avatar
Default Re: Vue V6
...For the 3.5L in the Vue, here's what listed:
I don't know who put together that data sheet but the 3.5 Honda engines are all SOHC, and have MFI fuel systems, including the one in the '04-up Vue. Seems as if the bit about the "Forged powder coated fracture split" connecting rods is also some mis-information. Con rods in both engines (which are near-identical, BTW) are sintered iron powdered metal, not "cast iron", not "powder coated". Sure is swell when they have non-technical people write these things, put them on the www spreading mis-information all over the place!
vue-vtec is offline   Reply With Quote
Old 02-17-2006, 09:19 AM   #11
fastdrvr23
fastdrvr23's Avatar
1992 SL1
Default Re: Vue V6
Damn, I just typed up a whole bunch of stuff only to close the window as my boss walked in.
I'll sum it up:
I screwed up typing the FPMFS part, it's actually Forged Powdered Metal Fracture Split. I type like a retarded ape with one hand. If I get a chance after lunch, I might talk with one of the people in the foundry about the con-rods, although I don't think we make any for Honda, I think our products for them are composite plastics for intakes or something.
They do have the 3.5L listed as a DOHC setup on this sheet, had I taken more than .01 seconds typing it, and actually thought about it, I'd have corrected it on the way. My bad for repeating it...
Ward's is the publication that sends us a quarterly spec sheet with all the autmotive applications that mahle produces products for. I work in IT, and it was given to me by a marketing person, who is going to get kicked square in the nuts, if he ever shows up to work. Maybe we have a contact at Ward's too, they need a good thrashing as well. Here's a link to the wall chart, with the same damn screwed up info! Arghh... http://www.us.mahle.com/C1256F7900537A47/vwContentByKey/W26LVHXZ845STULEN/$FILE/LV%20Chart%20-%20Inside%20Layout%20(2006).pdf
I hate I have contributed to the overall dumbing of the internet, no more posting for me, back to reading! Anyways, thanks for the heads up, I appreciate it.
2003 Mazda Protege5
1992 Saturn SL1
I am a rare breed, I own a 2003 Vue 2.2 CVT AWD Vue and Love it. JamesAWD Vue General 17 05-21-2007 12:15 AM
Attention Prospective Saturn Vue GL Buyer - The Vue GL Averages 26.1 mpg Vue GL Clev Vue Green Line 24 04-21-2007 07:57 PM
Perfectly Clears Compentition Short Throw Shifters for Vue/Redline Vue Speed Mafia Vue Mods 9 04-18-2007 11:14 AM
2006 Vue original seat covers fit 2003 vue?? Vuebots Vue General 1 07-09-2006 12:32 PM
2004 Saturn Vue Red Line: Finally, Some Zoom With a Vue (New York Times) DualCamCoupe Vue Red Line 21 03-17-2004 04:01 PM
