Old 08-10-2022, 03:46 PM   #5
Default Re: [2001 SL2] Losing coolant, but only when A/C is running?
S-series cooling fans run at one speed. You should hear it loudly. Worn out fans will appear to be working but are slower, reducing the forced airflow thru condenser coil and radiator. There's only one fan relay powering your single speed fan. One member discovered his replacement fan was wired in reverse.
