Old 08-09-2022, 10:47 PM   #3
N147JK
N147JK is a jewel in the roughN147JK is a jewel in the roughN147JK is a jewel in the rough
Default Re: 4-Pin Relay Orientation?
Thank you fdryer for that info - appreciated!
So, pin 30 always goes on the battery power socket. I checked the sockets with the power off. Interestingly, in 2 cases (the 2 smaller relays) there are 2 pins that both have 12 volts on them. One is the horn relay. I found that the horn works exactly the same regardless of which way the relay is inserted. I guess there are normally open and normally closed type relay circuitry.
N147JK is offline   Reply With Quote
