Thread: P0107 map
Old 02-28-2017, 09:05 AM   #1
bbender
bbender is on a distinguished road
Default P0107 map
I have a 1999 Saturn SL2. It runs poorly (limp mode?). Codes are: P0107, P0341 and P0404. I am most concerned with the P0107. I have replaced the MAP sensor with no change in condition. I have checked the 3 wires in the MAP sensor and I have good power, ground and signal.
I am thinking the problem must be the signal wire between the MAP sensor and the PCM. I will check that next. Anything else I should be checking? Thanks!
bbender is offline   Reply With Quote
