Old 07-07-2005, 02:32 PM   #3
mjo
mjo is on a distinguished road
mjo's Avatar
1995 SL2
Default Re: trans fluid/filter change will kill car?
I would buy Auto-RX and immediately put it in. This will help clean out all the buildup in your transmission. It works! Follow the Auto-RX instructions, they say to have a transmission flush done after 1500 miles (which you can do yourself if you are careful and have the right flare wrench). Then change to Mobil 1 and a good tranny filter. Mobil 1 keeps the transmission cooler and will protect the transmission more than regular ATF. A good tranny filter would be in my opinion a Purolator, ACDelco, or Baldwin. Don't get the cheap junk (eg. Fram) if you value your transmission.
BTW, you can purchase Auto-RX at www.auto-rx.com
mjo is offline   Reply With Quote
