07-17-2015, 10:21 AM
#5
2008 Astra XR
Re: How to - Camshaft actuator(phaser)/sprocket replacement
Originally Posted by smwalker
Very nice write up!
Could you post a picture of the outer bolt cover separate from the engine? What does it screw into? Are there threads in the cam shaft bolt recess?
Only part that is confusing.
SM,
Thank you very much! See if this helps, I assume you mean the upper timing belt/camshaft cover? It uses two (2) E-10 female Torx bolts for fastening.
If not, what section specifically and I will look to clarify. Thanks.
