Old 02-28-2021, 05:37 PM   #6
onlinebiker
Default Re: Engine Swap 1995 Saturn SL2
Also... If you run a later engine as a replacement - use the injectors from the 95.
The plugs are the same. The impedence is different - and if I recall correctly - you can burn things up by mixing early (pre 95) with 96 and later....
I ran into this in a swap on a 96....
Currently owned
93 SC2
96 SC2
97 SL2
98 SL2
99 SC2
01 SC2 auto
01 SC2 5 sp
02 SC2
02 SL2 auto
02 SL2 5 sp
parts
2 94 SC2 parted out
2 96 SC2
98 SL2
