Old 03-09-2021, 10:11 PM   #10
Becauseracecar
Becauseracecar is on a distinguished road
Default Re: headlight/DRL wiring questions with adding aftermarket lights
Originally Posted by billr View Post
You don't want to try using the high-beam indicator lamp circuit to control the relay? That seemed like an ideal solution to me.
If I had wiring schematics, or any idea where to access that circuit other than straight from the back of the cluster, then sure. But being that I don't have a pin out for the back of the cluster or any real schematics for that matter, and I haven't really had time to get into ripping the dash apart versus headlight wiring that was right there. I do agree that it would be a relatively easy solution though if I knew where to access the circuit
Becauseracecar is offline   Reply With Quote
