Old 04-11-2017, 12:43 PM   #1
mangler66
mangler66 is on a distinguished road
mangler66's Avatar
2007 VUE 2.2L
Default New lowering springs : is there any rubber part I should also replace?
Well after 10 years in the salt my Eibachs have had it, and I ordered some new Megan springs. My question is what do people usually replace at the same time? I found a rear lower lower rubber isolator and definitely changing those, but what about the upper? Should I be changing the bump stop? Fronts look OK still, and strut bearings are still good, so I think I'm OK in the front.
2.2L 5 speed, Eibach springs, Centerforce Df clutch, OBX LSD, ES poly sway bar bushings
mangler66 is offline   Reply With Quote
