Old 03-28-2008, 02:50 PM   #1
tacinc1
tacinc1 is on a distinguished road
Default Replaced VB, can elec. cause no reverse at all?
For this 2000 SL1 auto. tran. SOHC, I've put on 3 valve bodies and two
input shaft nuts. It is perfect in forward gears. Had reverse slam before I started. Did Wolfmans fix etc... No reverse. Someone said that I should have reverse even if the elec. connector on top of the valve body was unpluged. Or can the wires on the disc on side of the tran. under the brake fluid or the selector disc it's self cause a no reverse? Tks....
tacinc1 is offline   Reply With Quote
