Code 26 doesn't usually cause a driveability issue.
What year and model car do you have?
Oh never mind I found your other two posts on this. Like Ssicarman says check the search function for code 26 and you'll find a lot of info. But, it's probably not your stalling problem. Recheck your work, then check for vacuum leaks. Another possibility is that the hose to the map sensor- either at the sensor or at the back of the TBI unit- is old soft and may be pinching itself closed. Like Wolfman said, you also may want to check your coolant sensor operation
~ If it worked before you messed with it, it must be something you did ~
