Re: specifics on compression testing, P0301
The new spark plugs that I installed a few weeks ago are NGK, BKR4ESA-11 according to what is printed on the box.
The ones installed by a previous owner were autolite double platinum APP 3926, something I believe is specifically advised against for S series.
For my last test on reply #16, I removed all spark plugs, fully charged the battery, removed the PCM B fuse, and propped up the gauge on a large pair of channel locks in order to see the needle moving. The top row shows the results of that before adding oil, the bottom row shows results after squirting 1 TSP of oil in all of them with a syringe. For the tests with the oil added, the trickle charger stopped working (likely the faulty garage outlet), so I can not be sure if it was still fully charged.
I will need to conduct more tests on another day, I had other things today.
1997 V6 Mustang coupe 2018-2019(wrecked, airbags went off)
2001 SC1 2020-2021(wrecked, frame was bent)
1999 SC1 2021-now(working progress)
