Old 11-17-2021, 06:57 PM   #25
Default Re: specifics on compression testing, P0301
Yeah, we;re still kinda guessing here because we don't have numbers we can be confident in
Originally Posted by lanxer57 View Post
Does that apply to any engine? Even fuel injected ones?
Yes, the fuel supply doesn't matter. As a matter of fact, you should have pulled the PCM-B fuse out, as mentioned in the links I provided upthread. That shuts off the fuel injectors - which both prevents fuel from washing down the oil from the cylinder walls and throwing off your compression reading - by temporarily sealing any leaks.
You are taking a fixed amount of air at ambient pressure in the cylinder, compressing it, and seeing the pressure after compressed. A low compression number means air is leaking out, either past compression rings or valves (damaged/worn valve or valve seat). At higher altitude, that same amount contains less air to compress.
Originally Posted by OldNuc
Nominal compression for a high mileage good condition DOHC is 190-220psi and SOHC is 175-205psi.
Using the 80% adjustment fetchhitfido provided, the SOHC range should be 140-164 psi. Or 149-174 if you use your 85%
Do not screw it into the head past the point the sealing o-ring just contacts the head. Do not overtighten as it will leak.
