Oil leak
Ok, so my 04 Saturn Vue's oil pan is leaking. Any easy fix I've been told. Until then, what's the best type of oil to use? It calls for 5w 30, but it's also got alot of miles, a little over 200,000, so obviously a thicker oil for higher milage cars would probably be best, if it wasn't leaking. Also, I've used an additive that's supposed to reduce noise, smoke, an help prevent leaking by swelling the seals. My car only leaks, is this helping or should I avoid it?
