Old 09-26-2021, 08:30 PM   #2
Default Re: Does my 2006 Saturn Ion even HAVE a camshaft position sensor?
No camshaft sensor; http://www.saturnfans.com/forums/sho...d.php?t=219870
Under normal circumstances, a faulty camshaft sensor should be detected with a P0340 error code. P0300 is for a general misfire. If the crankshaft falters intermittently or fails outright, the engine stops running and cannot be restarted.
Replacing the coil pack is only half the ignition system. The ignition control module, sitting to one side of the coil pack may be the problem. ICMs fail more often than coil packs. Search past threads on 2.2L engines for common failures.
