Old 06-05-2022, 07:41 PM   #75
lanxer57
lanxer57 will become famous soon enough
1999 SC1
2001 SC1
Default Re: 1999 SOCH auto transmission problems
I did a test suggested by OldNuc in this thread. http://www.saturnfans.com/forums/sho...d.php?t=156458
The battery voltage was initially 12.6V, after charging it overnight, it only went down from there. Higher RPM only seemed to drain the battery faster. After turning on the headlights, opening the sunroof and windows, and turning on the A/C on full (There was not enough power for the radio), it had dropped to about 7V, the gauges were failing, and the idle became rough. It stalled about 30 seconds later when I tried to close the windows. There was not enough power to crank the engine, it read 12.0V. I managed to start it again a few minutes later, turned on the headlights and A/C, it stalled faster, and did not start again. I will change the alternator in a few hours, and see if that helps.
1997 V6 Mustang coupe 2018-2019(wrecked, airbags went off)
2001 SC1 2020-2021(wrecked, frame was bent)
1999 SC1 2021-now(working progress)
lanxer57 is offline   Reply With Quote
