Old 04-25-2020, 06:53 AM   #2
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Default Re: Saturn aura won't move in gear
Originally Posted by Coreykaq View Post
I've got a 08 saturn aura xe 3.5 I just replaced the 2-3 shift solenoid now it won't move in gear. It goes into park but every other gear feels like neutral. It just revs up but doesn't move. Any suggestions on what it could be? Also no check engine light.
What was the reason you changed the solenoid?
First thought is low fluid level since all gears are affected. Did you check the fluid level?
or
Plugged filter.
or
Broken shift linkage.
or
Bad torque converter.
