Old 03-01-2014, 02:43 PM   #9
glenstewart
glenstewart is on a distinguished road
Default Re: 04 Vue 3.5 won't crank turnover
Thanks very much for posting your approach. I used the same, and it worked nicely. One thing that threw me, was the placement of the rear battery tray bolt - it's BEHIND the front bracket for the fuse box, which rests on top of the battery tray. To gain access and keep things moveable, remove the two front 10mm fuse bracket nuts, and the rear fuse box bracket nut, located next to the strut tower nut.
Here's what the end of the starter looks like, once you clear the battery tray out of the way...
Originally Posted by talonsaab View Post
Just pryed the starter off. Remanufactured one cost me about $200 w/ 3 yr warranty. Install went a lot better except the battery tray is tricky because two bolts are blind. Once all back together started great. Its not that bad a job but does take some time due to the lack of space.
glenstewart is offline   Reply With Quote
