Re: 1999 SL1 rear brake line split - has the end come for the trusty Saturn?
Thanks for the replies and information. Does anyone have any thoughts on why the pedal goes to the floor even though from what I read the brake lines are divided front to back? Would something else also have to be malfunctioning, such as the master cylinder or a problem with the front brakes?
I was not losing brake fluid before this happened. Or can it happen for some other reason even though the brake system is redundant? I'm not sure exactly how redundancy works since whenever brake pads are replaced the brakes have to be pumped to purge air and pressurize the system(?).
Thanks for your help.
