Old 08-14-2009, 10:35 PM   #3
paul81
paul81 is on a distinguished road
paul81's Avatar
2003 L-Series 2.2L Sedan
Default Re: My battery is dead overnight
The battery is charging when the engine is running, yesterday I checked it and was ok. I will go out to look if the security light is on or off.
But still what do you think about the radio fuse, do you think there is a short on that circuit?
If the problem is only with the radio fuse, why my battery dies when is the bcm fuse connected? Do you think that I need to leave it for those 11 minutes and then the problem will be solved? Should I take it to a dealer? this is my only car and i don't have too much money to spend with this issue.
paul81 is offline   Reply With Quote
