Old 08-11-2008, 02:47 PM   #4
Bruce Rock
Bruce Rock is just really niceBruce Rock is just really niceBruce Rock is just really niceBruce Rock is just really nice
2000 SL2
2006 VUE 2.2L
Default Re: Pressure regulator cushion spring
I had planned on doing the nuts going into this. Never did the Wolfman's cure. Didn't want to waste the tranny fluid. And yes, both nuts were loose. I could remove the input shaft nut with the torque wrench set at 50 ft-lbs and it never clicked. The driven gear on the output shaft had a very slight wobble to it. I cleaned up the parts and put it back together using the original nuts but with red threadlocker. I had 0.014" clearance between the 1st drive gear and bearing. Specs call for 0.003" to 0.017".
Car has about 140,000 miles on it. Couldn't even see a wear pattern of the 1st drive gear or driven gear.
Local Saturn dealer says he can't sell me the cushioning spring. Have to buy a whole new valve body at $600.00+
