Old 09-25-2021, 10:21 AM   #8
Default Re: just replaced the valve body, new problems arose
There is a relearn process for shifting but each "gear" should work. The relearn process just reduces the "slam" into each gear, has nothing to do with where the gears are.
It's possible the shift selector got knocked out of alignment, but I'd expect odd gear locations on the shift lever rather than "everything is drive except park."
If the VB were rejected you wouldn't even have "D". Something went wrong with the VB reinstall and that was made worse by running it low on fluid.
