SaturnFans.com Forums
-   L-Series Tech (http://www.saturnfans.com/forums/forumdisplay.php?f=40)
-   -   4 Cyl. Ecotec Oil Pan Gasket. (http://www.saturnfans.com/forums/showthread.php?t=268475)
lrbraner 04-18-2021 03:14 PM
What is the recommended way to seal the oil pan when reinstalling?
After removing the pan I see little or no sign of sealant.
02 LW300 04-18-2021 06:40 PM
Re: 4 Cyl. Ecotec Oil Pan Gasket.
Use a high quality silicone gasket maker. I like to use gray since the engine is aluminum.
lrbraner 04-18-2021 07:54 PM
Thank you for the input.
Do you put a small bead on the inside edge of the pan as i have read ?
Or do you apply it down the middle?
02 LW300 04-19-2021 12:20 AM
I stay to the inside and go around the bolt holes. Let it cure overnight.
Rj 2000 LS2 04-19-2021 12:59 AM
Where do you get this idea to cure gasket maker over night? I recently posted Permatex's video link and directions that explicitly say put the two surfaces you want bonded together while wet, not cured. Do you know something the manufacturer does not?
Personally, I would extend the bead around the center and around each bolt hole (only on one side) and then assemble hand tightening each bolt in normal criss/cross fashion. Allow to cure for an hour and then torque to specs.
IMHO Allowing the gasket maker to cure over night will ensure leaks will occur. If the gasket material is not bonded to each clean surface, it will eventually leak. This is one time I will side with the manufacturer's recommendations.
02 LW300 04-19-2021 09:18 AM
Let it cure after assembly.
