SaturnFans.com Forums
-   Vue Tech (http://www.saturnfans.com/forums/forumdisplay.php?f=35)
-   -   04 Saturn Vue MT speed dependent hum- wheel bearing done (http://www.saturnfans.com/forums/showthread.php?t=268180)
jeopardy98 02-21-2021 02:50 PM
Hey All, well those that are left. My faithful Vue had a bad wheel bearing so I replaced it. I actually replaced 3 of the 4 this far but the hum didn't go away. I have added tranny fluid and I still get a hum. It is almost like it is coming from the CV joint but there is no clicking at full lock. The sound also gets louder when weighting the passenger side and quieter when weighting the driver side. It isn't significantly different but noticeable. The noise gets louder with speed and there is no change in gear or in neutral with the clutch depressed or engaged.
I'm racking my brain and cannot figure out what is causing the noise. Any ideas at all? Thank you in advance!
bluesl2 02-21-2021 11:39 PM
Re: 04 Saturn Vue MT speed dependent hum- wheel bearing done
It's most likely the one wheel bearing you have not replaced. The fact you said the noise changes when loaded then unloaded speaks volumes as to it being a wheel bearing. You have probably noticed, Vue's eat wheel bearings.
jeopardy98 02-23-2021 04:13 PM
[QUOTE=bluesl2;2357251]It's most likely the one wheel bearing you have not replaced. The fact you said the noise changes when loaded then unloaded speaks volumes as to it being a wheel bearing. You have probably noticed, Vue's eat wheel bearings.[/QUOTE]
I would have thought so too but that is the rear driver and this noise is 100 percent coming from the front left wheel. That wheel bearing has been replaced twice already. The 1st one failed after 500 or so miles and I replaced it under warranty. The one I installed on Saturday felt great but as soon as I took my test drive the noise is still there. Every part of me says it is another wheel bearing but the odds of getting another bad one are pretty low.
What am I missing? What else could make that noise? Why would it be faulty immediately after install? I am banging my head against the wall here. I appreciate any suggestions.
jeopardy98 03-02-2021 02:10 PM
Hey all, I'm still battling this. I noticed on a recent interstate trip that at 72 the noise begins to quiet and at 75 it is completely gone. At 76 it begins again louder than it is at 40-65. Any ideas at all as to anything else I can or should check?
waiter21 03-02-2021 06:54 PM
Did you also replace the idler bearing on the passenger side CV joint?
jeopardy98 03-11-2021 11:21 AM
Do you mean the jackshaft bearing? If so then yes, that has been replaced within the last 6 months. If I am not mistaken that sounded like more of a clunk when I was having an issue with that one. Or are you referring to a different part?
waiter21 03-11-2021 11:37 AM
The jackshaft bearing is the one I was refering to. Made a lot of noise on mine before I replaced it.
jeopardy98 03-11-2021 11:43 AM
Thanks for the suggestion. Mine was just clunky before I replaced it. That isn't to say it couldn't have gone bad again. I'm ready to burn this thing to the ground but I don't want to let it win either.
