SaturnFans.com Forums
-   S-Series Tech (http://www.saturnfans.com/forums/forumdisplay.php?f=39)
-   -   coolant level sensor (http://www.saturnfans.com/forums/showthread.php?t=270780)
Thorp 06-06-2022 11:36 AM
99 sl
I have had issues of bad heater cores in the past, so i am very alert about the low coolant light. It seems to be stuck on. I have checked, and triple checked the coolant levels, all good.
So, bad sensor? seems to just be a flaot, so i am not sure how it would really fail other than age. is this common?
Waiex191 06-06-2022 12:12 PM
Re: coolant level sensor
Here you go!
[url]https://youtu.be/-5814yr2p_Y[/url]
I've already got the merit badge.
Thorp 06-06-2022 01:06 PM
should have looked up good ole rich pin first .
Thorp 06-06-2022 01:09 PM
my tank looks very chalky, i fear i have some sort of coolant leak( strange temp issues, I dont like my needle movement) so when i saw this light, i freaked out. I had ordered a new tank a few weeks ago as it was the only thing I have not replaced. i think ill install the new one and clean the old one and see if that helps the issues.
