SaturnFans.com Forums
-   L-Series Tech (http://www.saturnfans.com/forums/forumdisplay.php?f=40)
-   -   2001 Saturn L300 (L81/3.0L V6) - Intake System + Camshaft Guards [Re-Assembly] (http://www.saturnfans.com/forums/showthread.php?t=268482)
BrandonKastning 04-19-2021 09:36 AM
5 Attachment(s)
This is Part.A.1 Gallery:
Best Regards,
~ Brandon Kastning :us: ;)
~ TruthSword
WE THE PEOPLE ONLINE
[URL="http://wethepeopleonline.com"]http://wethepeopleonline.com[/URL]
[URL="http://usconstitution.wethepeopleonline.com/guaranteed-and-protected-constitutional-framework-united-states-constitutional-articles/article-vi-prior-debts-national-supremacy-clause-oaths-of-office"]U.S. Const. Art. VI, Clause 2, 3 (1787)[/URL].
BrandonKastning 04-19-2021 09:37 AM
Re: 2001 Saturn L300 (L81/3.0L V6) - Intake System + Camshaft Guards [Re-Assembly]
5 Attachment(s)
Part.A.2 Gallery:
BrandonKastning 04-19-2021 09:38 AM
5 Attachment(s)
Part.A.3 Gallery:
BrandonKastning 04-19-2021 09:39 AM
5 Attachment(s)
Part.A.4 Gallery:
BrandonKastning 04-19-2021 09:40 AM
5 Attachment(s)
Part.A.5 Gallery:
BrandonKastning 04-19-2021 09:42 AM
5 Attachment(s)
Part.A.6 Gallery:
BrandonKastning 04-19-2021 09:43 AM
5 Attachment(s)
Part.A.7 Gallery:
BrandonKastning 04-19-2021 09:44 AM
5 Attachment(s)
Part.A.8 Gallery:
BrandonKastning 04-19-2021 09:45 AM
5 Attachment(s)
Part.A.9 Gallery:
BrandonKastning 04-19-2021 09:46 AM
5 Attachment(s)
Part.A.10 Gallery:
BrandonKastning 04-19-2021 09:47 AM
5 Attachment(s)
Part.A.11 Gallery:
BrandonKastning 04-19-2021 09:51 AM
2 Attachment(s)
Part.A.12 Gallery:
Got pretty close with Part A it seems! Also; if anyone was following my repairs. When I replaced the upper plenum and hoses for the PVC crankcase last year I ended up getting a new throttle body with it.
Ever since I installed that; is when the wrench light came on. Before re-assembling the upper plenum; I cleaned up my original throttle body that was working just fine and not giving wrench lights due to no ACDelco programming *which is what I discovered*.
I changed the gasket out and used RTV for the original cleaned up *looks brand new with how clean it is* and it's mounted and now installed with the upper plenum.
I will continue this with Part.B Galleries!
Best Regards,
~ Brandon :us: :yes:
Rj 2000 LS2 04-19-2021 02:40 PM
Brandon, don't attempt to start your engine after you reassemble the top end. The timing belt must be replaced and the timing set before you start your engine.
BrandonKastning 04-19-2021 04:58 PM
Rj 2000 LS2,
For sure! Thanks for the reminder!
[QUOTE=Rj 2000 LS2;2359793]Brandon, don't attempt to start your engine after you reassemble the top end. The timing belt must be replaced and the timing set before you start your engine.[/QUOTE]
BrandonKastning 04-19-2021 05:00 PM
5 Attachment(s)
Alright everyone! This should be everything on re-assembly for Part B (prior to the timing belt being replaced correctly).
I intentionally left the coil packs out until Part C. (due to timing belt and less resistance on the crankshaft per members here).
Thank you all again! :)
Gallery Part B.1:
BrandonKastning 04-19-2021 05:02 PM
5 Attachment(s)
Gallery Part B.2:
BrandonKastning 04-19-2021 05:03 PM
5 Attachment(s)
Gallery Part B.3:
BrandonKastning 04-19-2021 05:04 PM
5 Attachment(s)
Gallery Part B.4:
BrandonKastning 04-19-2021 05:06 PM
5 Attachment(s)
Gallery Part B.5:
BrandonKastning 04-19-2021 05:07 PM
5 Attachment(s)
Gallery Part B.6:
