SaturnFans.com Forums
-   S-Series Tech (http://www.saturnfans.com/forums/forumdisplay.php?f=39)
-   -   02 SC2 Intermittent reverse lights (http://www.saturnfans.com/forums/showthread.php?t=267822)
Dans sl2 04-08-2021 09:33 PM
Re: 02 SC2 Intermittent reverse lights
I was having the same issue. When I installed a new clutch I took a flat file to the switch mating surface on the shift tower. I couldn't tell you how much material I removed but I kept filing till the switch would come on reliably and repeatably. That was my cheap fix and it was fairly easy since I already had the shift tower off. I have also thought of machining a switch but don't have access to a lathe. I would have to pay a local machine shop to do it for me. I was going to have them take off .050" and then shim back up if I needed to. Billr how much did you remove from the switch you machined for Mistahsnowman?
billr 04-08-2021 09:57 PM
It was .060-.065" The ones I cut were made from "screw-machine" stock, [I]very[/I] easy to machine.
