Old 05-17-2007, 03:08 AM   #1
danlew10
danlew10 is on a distinguished road
Default 1997 Saturn sl-1 will crank but wont start
When I first cranked it up this morning it started for a second and then quit. It will crank all day. I checked the fuel pump fuse and relay. I can hear the fuel pump when the ignition is turned on. It has some relatively new coils and sparkplug wires. Can someone help me?
Add to danlew10's Reputation
Rate the quality of this post and help danlew10 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
danlew10 is offline   Reply With Quote
Old 05-17-2007, 03:59 AM   #2
Default Re: 1997 Saturn sl-1 will crank but wont start
Welcome to Saturnfans! Newbie mistake posting in the wrong forum - you should be posting in the S-series as your brethren are in greater numbers but either re-posting there or pm'ing the Administrator to move your post will suffice.
Cranking till the battery dies and assured of fuel pressure to the injectors is good enough to come right out with your crank position sensor (CPS) is the lazy one preventing an engine run. To be absolutely sure pull the #1 and #4 coil wires and crank the engine again; no spark jumping across the coils is another indication of a failed/failing CPS. It's located above and behind the starter with a single 10mm bolt.
Old 05-17-2007, 05:46 PM   #3
danlew10
Thanks, The CPS did the trick.
01 saturn l300 wont start heavyspitters L-Series Tech 12 12-16-2009 08:07 AM
1997 Sl2 cranks but wont start Mdawg2009 S-Series Tech 3 12-14-2009 08:23 PM
2000 Ls2 was running fine... now wont start!! Will crank, not turn over... dustinv123 L-Series Tech 5 12-02-2009 12:28 AM
Thinking about buying a '96 SL2 that wont start/crank & is low on oil... 1999_Saturn_SC2 S-Series General 6 11-21-2009 10:35 PM
my 1997 sl2 wont start Chromebuster83 S-Series Tech 5 04-29-2009 09:52 PM
