Old 05-15-2007, 10:33 AM   #1
netsniper
netsniper is on a distinguished road
Default 92-93 block 97 head?
Ok, SO I have a question. Will a 92-93 block that was originally sohc 8v with dished pistons work with a newer 97 dohc head? Plus I was reading that there was a restrictor plug in the oil gally going to the head does that need to be removed in order to usea newer style head gasket....? Please help I hate saturns.... and you guys know more than me...
Add to netsniper's Reputation
Rate the quality of this post and help netsniper reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
netsniper is offline   Reply With Quote
Old 05-15-2007, 11:27 AM   #2
BarnOwl
BarnOwl's Avatar
Default Re: 92-93 block 97 head?
I'm not sure about the '93 but, I don't think the '92 will work. The '97 PCM won't work with the reluctor on the '92 crankshaft. The '93 PCM won't work with the linear EGR valve on the '97 head. There are adapters that will take adapt a head that took a vacumn operated EGR take an electronically operated one but, I'm not certain they'll work the other way.
Add to BarnOwl's Reputation
Old 05-15-2007, 11:28 AM   #3
CrewCab
CrewCab will become famous soon enough
CrewCab's Avatar
2008 AURA XE
It depends, if it is a 92 or a 93. The reluctor ring on the crank is different 91-92 from 93-02
Yes. You need to remove the plug. The head gasket is designed to contol the oil pressure to the head.
I used a 94 block with a 96 head in my 96 SL2
Add to CrewCab's Reputation
Rate the quality of this post and help CrewCab reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
CrewCab is offline   Reply With Quote
Old 05-15-2007, 11:37 AM   #4
netsniper
The car is originally a dohc but there are holes in the block I want to use this unknown year sohc block with the original 96 dohc head but I think the valves may hit the pistons
Unknown sohc block
96 Dohc head
Old 05-15-2007, 12:02 PM   #5
Dr B
Dr B is on a distinguished road
Dr B's Avatar
1992 SL2
1993 SL2
I think others have put D O H C heads onto blocks with dish pistons,
the engine is of the interference type regardless of the piston design.
your big IF is ,is this block 93 up ,the reluctor on 91-92 won't work!
on the 93 up setup ,you could put a newer crank in ,and GO
Have A Great Day , it is YOUR choice !
Add to Dr B's Reputation
Rate the quality of this post and help Dr B reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dr B is offline   Reply With Quote
Old 05-15-2007, 12:17 PM   #6
netsniper
How can i tell the year of the block?
Old 05-15-2007, 12:18 PM   #7
Wouldn't the EIN date the block?
Add to madpogue's Reputation
Old 05-15-2007, 12:28 PM   #8
netsniper
Yes where is it on the block?
Old 05-15-2007, 12:34 PM   #9
Dr B
Dr B's Avatar
1992 SL2
1993 SL2
on the front side ,below where the coil pack ,on trans ,meets block
on that lip ,there is also one on the trans parallel ,the V I N s
Old 05-15-2007, 01:13 PM   #10
netsniper
Uhoh its a 91
head/block before/after should i resurface 93SC2'in S-Series Tech 11 11-15-2008 11:03 PM
'96 head on '99 block? cuff S-Series Tech 5 08-05-2008 01:08 PM
98 model head and intake on 01 block.. a88ruby S-Series Tech 3 02-26-2008 06:21 PM
can you put a 2.4 block on a 2.2 head jhutch2115 Ion General 3 07-28-2005 02:50 AM
99 block with 92 head elvinrodr Mods and Performance 6 01-28-2004 09:56 PM
