Old 05-13-2007, 11:24 AM   #1
Alex-SW2
Alex-SW2 is on a distinguished road
Default TCC Solenoid
Hello again,
I have been having the “Service Engine Soon” warning light come on lately on my 1999 Saturn SW2 DOHC wagon which I just bought it last Christmas. It has about 112,000 miles on it. The error code is P0741. I have had the tranny filter and fluid changed, but am still experiencing the problem. I reported this in an earlier thread (Feb /07). I haven’t done much about it yet, but I have had the error code confirmed by my local Saturn dealer.
Can anyone please tell me if anyone has seen a procedure on this site for replacing the TCC solenoid or is it recommended to purchase the shop manual instead? I would like to try to do this myself if the procedure isn’t too complicated.
Add to Alex-SW2's Reputation
Rate the quality of this post and help Alex-SW2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Alex-SW2 is offline   Reply With Quote
Old 05-13-2007, 11:55 AM   #2
wolfman
wolfman's Avatar
Default Re: TCC Solenoid
The solenoid itself is built into the upper valvebody of the transaxle, it can be changed without removing the transaxle, (get a manual) however, it may not be the solenoid at all, but the TCC (torque convertor clutch) itself, which is a much more involved undertaking. Perhaps a rehash of your actual symptoms might help..
Add to wolfman's Reputation
Old 05-13-2007, 07:45 PM   #3
Alex-SW2
A little bit of the history of this problem… The car has an automatic transmission. When I am driving along and start to go up an incline, the “Service Engine Soon” light comes on when the transmission downshifts from 4th speed to 3rd speed. I think this is only condition that causes the light to come on that I have noticed. The light will stay on usually for about 3 days. If I am very light on the pedal going up grades, the error code will clear itself. Sometimes I will put the transmission in 3rd to prevent the light from coming on.
Old 05-15-2007, 01:11 PM   #4
reemoe
reemoe is on a distinguished road
1995 SC1
Although I'm not getting a SES light, I'm having a problem that I believe may be TCC related.
It typically occurs when going 50-55 mph going up a hill. It feels as if the tranny is slipping, as the car vibrates quickly for about a second. It doesn't always occur, and sometimes a loss of acceleration is felt.
Any ideas? TCC solenoid, fuel pump, spark plugs...?
Thanks for the help!
Ryan
Add to reemoe's Reputation
Rate the quality of this post and help reemoe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
reemoe is offline   Reply With Quote
Old 05-15-2007, 08:04 PM   #5
This is a TCC stuck off code. I suspect that the downshift that you feel is not a 4 to 3 but a TCC coming off rather than an actual gear downshift.
From the service manual.
DTC P0741
Circuit Description
When torque converter clutch (TCC) is commanded ON, the comparison of engine speed to input shaft speed is monitored to assure TCC is ON. When the TCC is ON, the engine speed and input shaft speed are equal. TCC is applied by grounding circuit 422.
Conditions for Setting the DTC
DTC P0741 is set when the PCM has detected the following conditions for more than 7.5 seconds twice per ignition cycle:
• The transaxle fluid temperature is above 20°C (68°F).
• No engine or input shaft speed, or signal noise DTCs.
• Engine speed is greater than 908 RPM.
• Input shaft speed is greater than 224 RPM.
• TCC has been commanded ON for more than 5 seconds and there has been no gear change.
• Speed difference across the torque converter is greater than 280 RPM.
Test Description
Numbered steps below refer to numbered steps on the chart.
Check for DTCs P0740, P0743, P0744, P0756, P0758, P0759, P0761, P0763, P0764, P0766, P0768, P0769, P0781, P0782, or P0783. They must be eliminated first as a possible cause of DTC P0741.
Check the solenoid operation. Use the solenoid quick check in the test section located at the end of the DTC charts. The actuator quick test will PWM the solenoids at a set rate. Listen and compare the noise of the TCC gear solenoid to that of other solenoids. The noise of all should be similar.
Important: To check solenoid operation, command the solenoid quick test using the scan tool.
Other possibilities for DTC P0741 to set:
- Internal leakage in the TCC apply circuit
- Possible low line pressure
- Converter charge valve stuck causing TCC apply pressure to be exhausted to lube
- Converter limiting valve stuck open
- Missing or damaged torque converter-input shaft O-ring
Repair Verification
Monitor the DTC menu Code Status for Pass Since Code Clear and Pass This Ignition Cycle. When both have passed, the repair is verified.
Criteria for pass:
• The TCC is commanded ON.
• The ratio across the torque converter is 1:1 for 12 seconds.
Diagnostic Aids
• When the PCM detects a fault in the circuit, an open, ground, or short, the PCM will open the circuit internally to protect the circuit.
• This DTC may be caused by a poor electrical connection at either the PCM, actuator connector plate, IPJB terminals, or UHJB terminals. Wiggling the connectors while performing an actuator quick test may help isolate the problem area.
• Due to the clutch priority valve, this DTC will be set when 2nd, 3rd, or 4th gear is determined to be stuck ON.
TCC Apply
- The engine temperature is above 20°C (68°F).
- The vehicle speed is above 26 km/h (16 mph).
- The transaxle fluid temperature is above a given value in relation to the intake air temperature (IAT) sensor value.
TCC Release
- Low engine speed downshift, e.g., light throttle or steady throttle, with load increase.
- Low end of the 3rd gear speed range, brake ON equals TCC OFF.
- Fast deceleration, i.e., brake lock on ice equals TCC OFF, gear equals neutral.
You need a tech 2 scan tool to do the main first diagnosis in the diag chart--the solenoid check. If the solenoid sounds good then it likely a mechanical component failure.
Check the wiring to the trans and the trans fuses in the under hood fuse block.
Add to ssicarman's Reputation
Old 05-15-2007, 09:16 PM   #6
Alex-SW2
Thanks to all for taking time to reply! This information is very useful. I'll have to invest in a proper scan tool to perform this check. I think the factory manual would also help. I have the Haynes manual, but it doesn't cover transmission issues in great detail.
It may take a while, but I will working on this problem over the next few weeks as time permits and will report my progress.
Old 01-21-2011, 07:57 PM   #7
NoRicer
NoRicer will become famous soon enoughNoRicer will become famous soon enough
Sorry Iam posting this on an old thread but for some reason iam not allowed to start a new thread..
anyways. I just got a 1999 SL2 that a used replacement engine was put in and it has never moved because it has an active code of P0742 TCC stuck open. (was ok before engine swap) Torque conv. is defininitly in lock-up as it kills the engine when put into any gear. I did ohms checks on all the solenoids 5.6 oms. tested with power all clicks the same, pulled the TCC solenoid and was able to blow through it with out power and with power applied it closes off as it should. tested the connector plate, no opens or resistance. Put it all back together and tried it and still same prob. TCC fuse power good, continuity check hot wire from fuse to trans pin connection, good. signal wire from trans. pin connection to pin on PCM all good. with engine running I applied direct ground from PCM ground TCC signal wire, got a little spark with the load of the solenoid and still the Torque conv. locked up and kills the engine.... I am afraid that its something major. My TAAT manual says this code is a Electronic fault and not mechanical.... Help.
Add to NoRicer's Reputation
Rate the quality of this post and help NoRicer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NoRicer is offline   Reply With Quote
Old 01-21-2011, 08:18 PM   #8
Chazberry
Chazberry's Avatar
See if these FSM pgs. are helpful . . .
http://i814.photobucket.com/albums/z...g?t=1295659009
http://i814.photobucket.com/albums/z...g?t=1295659057
Add to Chazberry's Reputation
Old 01-24-2011, 10:44 AM   #9
NoRicer
Thank you Chazberry
Old 01-24-2011, 12:21 PM   #10
OU812
OU812 has a spectacular aura aboutOU812 has a spectacular aura about
1996 SL1
Do an ohms test on the TCC solenoid for starters
Add to OU812's Reputation
Rate the quality of this post and help OU812 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OU812 is offline   Reply With Quote
Old 01-24-2011, 06:18 PM   #11
NoRicer
I did ohms checks on all the solenoids 5.6 ohms.
I ordered a new solenoid and will replace it, If that's not it.... torque conv. or input shaft seals???
Old 03-26-2016, 09:34 PM   #12
Turboturtlesl2
Turboturtlesl2 is on a distinguished road
Ok so i have a problem with my transmission i have narrowed it down to my tcc solenoid. Ive read all the the post and everyone is saying everything my car is doing. Everyone is very helpful but i know that this is my issue i just cannot find the solenoid anywhere! Does anyone know the part number and or somewhere i can buy it.
Add to Turboturtlesl2's Reputation
Rate the quality of this post and help Turboturtlesl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Turboturtlesl2 is offline   Reply With Quote
Old 03-26-2016, 11:05 PM   #13
Chazberry
Chazberry's Avatar
PN 21003344
I bought my last one off Amazon. You should be able to find one for about $50.
http://www.amazon.com/General-Motors...words=21003344
Anyone in the Toronto area who can change my TCC solenoid? 93 SL1 Canada S-Series General 9 01-11-2010 01:42 AM
worn TCC/ TCC problems datstrukid S-Series Tech 0 10-16-2008 10:21 AM
TCC solenoid stuck off DTC 741 breasonable S-Series Tech 3 08-10-2008 08:54 AM
How can you tell if your PCM or TCC solenoid are bad? Joe SL2 S-Series Tech 1 02-09-2008 01:49 AM
Location of canister purge solenoid and vent solenoid? jslw300 L-Series Tech 2 05-05-2005 06:36 PM
