Old 05-08-2007, 01:51 PM   #1
microsat
microsat is on a distinguished road
Default which coolant is best for saturn 2002 sl2?
Hi there,
which coolant is best for saturn 2002 sl2, dex-cool or regular green coolant?
Saturn's manual says that it recommends the dex-cool. But online a lot of people complained about it. can anyone give your opinions about it? thanks.
Van
Add to microsat's Reputation
Rate the quality of this post and help microsat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
microsat is offline   Reply With Quote
Old 05-08-2007, 01:59 PM   #2
TXSaturn02
TXSaturn02's Avatar
Default Re: which coolant is best for saturn 2002 sl2?
Madpogue's opinions are pretty good. He already stated that as long as it was dex-cool compatible, the color makes no difference. Based on what I've read here in the last few months, it isn't that important. As long as you change it out regularly, but I'm no expert.
New owner As of 01/01/18: 225,000 Miles
As of 05/10/18: 48,065 Miles
Old 05-08-2007, 04:05 PM   #3
From what I've read (note: NOT direct experience), the "bad stuff" you hear about dex-cool is in cars with a true "overflow" bottle. That is, there's a radiator cap with a pressure release, which draws from and dumps to a bottle that's NOT under pressure. Supposedly something bad happens to the coolant sitting at atmospheric pressure. Our cars have no radiator cap; the only outside world interface (presuming no leaks!) is the reservoir cap, and the reservoir is part of the pressurized system. Other drawbacks of this kind of system aside, as I understand it, dex-cool is fine in systems of this kind.
Add to madpogue's Reputation
Old 05-08-2007, 04:13 PM   #4
SaturnManiac
SaturnManiac's Avatar
The best kind is the kind that you put into the toilet when you use it, LOL.
Nah, I'm kidding, seriously don't put urine in your radiator, LOL....and you really wouldn't want brown turdy chunks floating in it either.
DEX-COOL is fine, you can use the regular green stuff, but if you already have DEX-COOL in there, I'd stick with that, or you *can* mix the Prestone mixes with any anti-freeze in there. If you use the green stuff, you just have to flush it out more often. Just make sure you don't use only anti-freeze, you are supposed to mix it with water, or you can buy the pre-mixed stuff. You'd be amazed at how many times I've seen morons pour pure anti-freeze into the reservoir/radiator....when the back of the bottle clearly says to mix it with water. It's supposed to be a 50/50 mix, but some people do a 60(anti-freeze)/40(water) mix, which is also fine.
Add to SaturnManiac's Reputation
Rate the quality of this post and help SaturnManiac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-09-2007, 12:14 AM   #5
eRic 02sc2
eRic 02sc2's Avatar
Originally Posted by microsat View Post
Hi there,
Van
use Dexcool like the Saturn handbook says. if you don't and something bad happens, your Saturn retailer will blame it on you not using Dexcool when you take it in for service.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 05-11-2007, 10:10 PM   #6
saturnsctwo
from what i understand the dex-cool is designed for aluminum blocks. it's more corrosion resistant than the green coolant. the bottom line is you should use what the manufacturer recommends....
Old 05-11-2007, 10:13 PM   #7
saturnsctwo
i was never a fan of overflow bottles. the coolant in the bottles tends to get dirty & the walls of the bottles get slimy with deposits & eventually those contaminants get in the radiator causing corrosion. i think the saturn's system is much better designed to not allow this from happening. my "overflow" bottle was clean inside after 7 years....
2002 Saturn Vue Oil in the Coolant brokenhammer Vue Tech 10 09-21-2014 11:05 PM
Coolant Flush 2002 SL2 eric_w S-Series General 3 08-10-2009 09:25 AM
Gawh! Was anybody able to remove coolant drain plug for SL2(2002)? latestgood S-Series Tech 13 11-14-2008 07:42 PM
Engine coolant change Saturn SL 2002 pedros003 S-Series Tech 20 03-25-2007 01:40 PM
Saturn SL-1 2002 - Coolant Light/Coolant Leak - Muffler noise - Check Engine Light unabelladonna S-Series Tech 1 02-26-2007 11:56 AM
