#1 | ||||
I've only seen my car go above the halfway mark once or twice, and anybody who knows me on here knows that I drive the #@&% out of my car. I'm obviously doing something right in my choice of coolant or oil or something.
With that being said, though, looking at the lines on the coolant temp gauge really tells me nothing. (I'm an engineering student, and while I can figure out that anything in the red zone is bad, numbers mean a lot more to me.) What temperature corresponds with each of the lines on the dash gauge? In an approximate sense, what oil temperature can I expect at each of these temperatures? Thanks.
#2 | ||||
Look up SkyKing's posts on calibration of S-series temperature gauges, It may not apply but is relatively close otherwise try using a hand-held infrared pistol-grip temperature probe.You might find one from one of your departments.
#3 | ||||
![]() Join Date: Jul 2004
2006 ION-2 Sedan
To be honest, there is no rhyme or reason to the gauge readings, since it starts registering temps as low as ~120dF but halfway is over 200.... as long as the fan works and you hear it come on, you are safe.....
... GM, Saturn, and ASE certified Technician. Always glad to try to help, just ask!!! Now own an 06 ION.2 as of 7/2/06 with 2988 and counting (7/28/06) 13131 as of (1/8/07) 24901 as of (7/30/07)
#4 | ||||
Being within a margin of safety isn't the point. I want to know the coolant temp so I can guess/calculate what the oil temp is so I can determine the fluid properties to figure out the real parasitic losses in the engine due to fluid viscosity. Eventually this will prove or disprove my theory that the engine oil never approaches its rated upper viscosity of 30 at 100C.
#5 | |||||
2006 ION-2 Sedan
#6 | ||||
Hrmmm... max lubricity is somewhere around an oil temp of 220 IIRC.
| Thread Tools | |
| Display Modes | |
| Changed coolant, temp gauge reads warmer | mr18436572 | S-Series Tech | 10 | 11-25-2009 07:58 AM |
| Coolant temp gauge | L200Pilot | Astra Tech | 30 | 04-29-2008 07:14 AM |
| Flashing warning light above coolant temp gauge | SLoneDC | S-Series Tech | 15 | 04-06-2007 06:32 PM |
| Does Temp Gauge Read Right When Low on Coolant? | spencerb | S-Series Tech | 11 | 12-09-2004 10:48 AM |
| Coolant Temp Sensor - Fan or Gauge? | petemcs | Miscellaneous Tech | 3 | 01-05-2004 09:37 AM |
